injector line broke!
Old Jun 13, 2008 | 09:43 PM
mrploww's Avatar
2001 Cummins 6 speed
I was driving home last night and the truck started running weird like it was not firing all cylinders. I pop the hood and see diesel squirting out from the #3 injector line. It looks like it broke about halfway between the pump and injector. Is this something that a dealer would carry? Is there a temp fix I can do to at least drive the truck until I get a new one?
Thanks for the help!
Old Jun 14, 2008 | 01:25 AM
Clayten's Avatar
DTR's Toad Wrangler
No temp fix you need a new one. Cummins would be my first place to get one.
Old Jun 14, 2008 | 05:23 AM
It happens. I've seen lines patched with compression unions. It's not pretty but they made it into the shop under their own power. If you need to use the truck it won't hurt anything. The Dodge dealer can get one for you but they will get it from Cummins and mark it up some more. Go no Cummins' website and find your local Cummins distributor. Call them and they will ship you one, when I order parts from the Harrisburg warehouse I usually have them the second day.
Old Jun 15, 2008 | 09:49 AM
Bad Ramer Jamer's Avatar
Same thing happened to me. Mine came apart at the injector. It was caused by a loose line clamp that I kept forgeting to tighten up. It vibrated itself apart.
Dodge wanted $59,,,Cummin's GOT $24.
Old Jun 15, 2008 | 09:57 PM
mrploww's Avatar
Well, this one was $80 from the Cummins dealer. I spent 2.5 hours trying to install it and gave up. I had it towed to Cummins and the mechanic ended up removing all of the injector lines and got this one installed. And this is the amazing part...they didn't charge me to do any of it!!! Now, THAT is service!
smokeum99ta
Dec 8, 2017 01:32 AM
county cowboy
Feb 13, 2007 09:25 AM
Jambbii
Jul 27, 2006 05:06 PM
whittysram
May 22, 2005 01:52 AM
