injector line broke ?
Old Feb 12, 2007 | 08:32 AM
county cowboy's Avatar
other day was going down road and truck started runing funny then got worse . fuel psi was going 8 to 10 to 8 to 13 to 7 ect.
opened the hood up and # 3 injector line was broke in half i was looking @ it and this is the only line or one of them that dont have a brace holding it down its on the bottom .
is this normal ? and where is a good place to find lines at ? its a 99 dodge 2500 diesel .
Old Feb 12, 2007 | 08:52 AM
need12v's Avatar
Go to your local cummins dealer for a replacement. I havent heard of it happening much on CTD's but every once in a while, esp with the older equipment I run, I lose one and go straight to mother deere to find one.
Old Feb 12, 2007 | 12:39 PM
ouchhhh one dealer was $140 other one was $112 (this one is dealer discount ) thats just for the 1 line thats crazy .
Old Feb 12, 2007 | 12:44 PM
John Faughn's Avatar
See if you have a shop in your area that makes hydrolic hose's lines , they should be able to make one for less than that , bring in your old one , to match , also incase they may be short of the fittings .
Old Feb 12, 2007 | 02:08 PM
bent valves's Avatar
Not having a brace is the problem. Sometime when your engine is running put a finger on one of the high-pressure injector lines. You will be surprised how much pulsing there is. I just checked my engine and counted 3 line clamps securing the number 3 line. Starting at the head the first clamp is rearward about 4” and connects line 3 with line 6. It then loops forward to a second clamp that connects line 3 with line 2. Then there is an “S” bend to the third clamp on the edge of the intake manifold where lines 2 and 1 join it.
I read somewhere the reason these lines snake around like they do is to make them all identical in length. This is to keep the injection-timing event the same on each cylinder. If you are not going to use a Cummins line, be careful to find a quality replacement.
Old Feb 12, 2007 | 09:43 PM
mini14's Avatar
correct, all the lines are the same length for timing
Old Feb 12, 2007 | 09:48 PM
dj_souvlaki's Avatar
ya without the bracing a injection pump produces so high of a psi that the lines will try to straighten themselves out
Old Feb 13, 2007 | 09:25 AM
thanks guys that info is good stuff i will make shure i fix this prob with new line . my guy found me one in FL used off a pretty new motor for 70 $ beats the $ 140
thanks
smokeum99ta
Dec 8, 2017 01:32 AM
mrploww
Jun 15, 2008 09:57 PM
Jambbii
Jul 27, 2006 05:06 PM
whittysram
May 22, 2005 01:52 AM
