Ignition Switch Stuck
Old Sep 11, 2009 | 05:47 PM
M1AM14SPUR's Avatar
Exclamation Ignition Switch Stuck
I am stuck on the side of a big hill. I went to start the truck, I gave the wheel a litle pull to turn the key, Truck started but the steering wheel is locked. Anyone have any magic spells for this one? Thanks again ya'll!
Eric
Old Sep 11, 2009 | 11:15 PM
M1AM14SPUR's Avatar
I really need to see if any of you have dealt with this.
I am facing downhill in the woods. There isn't anything under my front tires except leaves. I have rocked it back and forth, jiggled the key 2.4 million different directions, yelled, cussed, cried and came close to shooting it.
I don't know what kind of animal lives in the key switch to lock the steering wheel, but it has to be the culprit. Any of ya'll know about this area?
I took the top & bottom cover off around the column, & I don't see anything.
Old Sep 11, 2009 | 11:32 PM
96_12V's Avatar
Mine is totally different - being a 2nd gen.
Only thing I've ever done is move the steering wheel right or left, usualy about 1/2" does the trick.
If not - call a tow... you don't want to have that airbag go off in your face...!
Good luck...
Old Sep 21, 2009 | 01:05 PM
eastmentCTD600's Avatar
turn the wheel as much as you can in one direction and try the ignition, if that does not work turn the wheel in the other direction and try the ignition.
Old Sep 23, 2009 | 03:25 PM
Slice's Avatar
gear shifter dont ask how i know
Old Sep 23, 2009 | 06:59 PM
77machomopar's Avatar
manual trans
thats a far fetched answer to his problem being a 6sp truck
jon05ctd
Apr 16, 2010 01:53 PM
heath
Dec 11, 2009 05:39 PM
Baja
Jan 29, 2008 08:17 PM
GaCamper
Dec 1, 2003 08:59 PM
D4Fritz
Mar 16, 2003 03:55 PM
