New engine it & no start!
Old Sep 10, 2009 | 05:30 PM
Mopar_Man's Avatar
New engine in & no start!
I got my new engine in & it isnt starting, It has 17psi of fuel preshur at the injection pump. does anyone have any ideas? please help. BTW all mods are listed in hte sig. TIA
Old Sep 10, 2009 | 07:00 PM
wyododge's Avatar
Did you 'crack' the injectors?
It may be a dumb question but hey at least you will get bumped!!!
Old Sep 11, 2009 | 11:58 AM
Mopar_Man's Avatar
Yes, but seeing how the entire fuel system was apart I think there is still to much air in the system, Or it could be the injection pump timing.
Old Sep 11, 2009 | 12:03 PM
patdaly's Avatar
You need to bump the started multiple times without turning over the engine, each time should let you LP run for 25 seconds.
I can usually tell a difference in the LP sound when she is finally pushing diesel.
Then crack at least 3 Injectors and she should fire off.
Your pump timing should not be able to be off unless you put the wrong number Key in, or you got your front geartrain n wrong.
Old Sep 11, 2009 | 12:06 PM
Mopar_Man's Avatar
There is fuel at the IP, 17PSI at the Injection pump. Wrong # key in? how many diffrent ones are there?
Old Sep 11, 2009 | 03:30 PM
Mopar_Man's Avatar
We got the problem figured out, When I got the engine it was set to TDC but it was on the exhaust stroke instead of the intake stroke, So the injection pump timing was 180* off. Pulling the rad, intercooler & cover off to reset the timing gear for the IP
Old Sep 11, 2009 | 04:09 PM
patdaly's Avatar
Not sure just how many, but there are multiple ones, your pump will have the key number on it somewhere. They say in the rebuilt pump instructions to make sure the number on the key matches the number on the pump.
Old Sep 12, 2009 | 02:18 AM
wyododge's Avatar
Okay, doctors orders, you need WAY MORE BEER when you work on your truck!!!
Gald to hear you got it figured out!!
Old Sep 12, 2009 | 03:51 PM
blackfordd's Avatar
He works at a place called the "Pitcher House" for goodness sakes!! Glad you got things going Zeb. Can't wait to see and hear the truck soon!!
David
Old Sep 24, 2009 | 01:26 PM
Mopar_Man's Avatar
well we thought that was the problim & after checking it that is not what it was, But I do think we got it figured out, It has a CR head on it, So the connector/crossover tubes were not connecting with the injectors & no fuel was getting in to the engine. So I got ahold of some custome crossover tubes made by Monster Mike that should be here today & finaly get this thing on the road.
Tsutter
Mar 16, 2012 05:11 PM
CoolumConst
Oct 11, 2008 10:00 PM
Bobcat698
13
Jan 24, 2008 08:45 PM
Ridiculous
May 17, 2007 07:28 PM
ticki2
Dec 4, 2004 03:26 PM
