I have codes 1693 & 1689
Old Aug 26, 2006 | 05:36 PM
Carl05's Avatar
This is kinda long..
I was getting injection timing error code and a 1693 (I think). So I had the truck looked at down at the dealer and they told me I needed a new VP44. So I went and had a new one put in.
After I got my new IP installed it ran fine for a few days, and then it started missing like the pump was going bad again. (But I had no codes) So I changed my fuel filter yet again and installed a fuel pressure gauge. While I was installing my FP guage I tried to start my truck with out having the wires to the VP44 pluged up because I had forgot I unpluged them to start with.
Now I have my gauge in and at idle I have 11 fuel pressure, and I am also getting error codes 1693, and 1689. Are the codes because I tried to start it with out having the IP plugged in? or do I have to buy something else? Is 11 at idle good or bad?
Thanks,
carl
Old Aug 26, 2006 | 05:40 PM
Carl05's Avatar
I have a 2001 dodge ram 2500 btw. I can't see my sig for some reason...
Old Aug 26, 2006 | 10:32 PM
blackdiesel's Avatar
Registered
Yes. the code you got is no connection between ecm and vp44, does it run now? and if so how? did the dealer put on a L.P. also? did they test it? what kind of pressure at w.o.t.?
Old Aug 27, 2006 | 12:24 AM
Carl05's Avatar
Dealer did not install the new pump, but the truck does run.
It has not been cutting out on me since I installed the new filter, and gauges.
(But I only drove it for about 3 miles)
At WOT the pressure drops down to about 4-5.
After all of the money I have spent on this truck in the last year getting
things fixed every little thing makes me paranoid now.. lol
Old Aug 27, 2006 | 08:05 AM
Registered
I know your PAIN. I would want to do some thing about that pressure 4-5 is getting to low. ether a new stock, a holley blue helper or go for the fass. IF it were mine I would put a blue on it, it will cost you $110 for blue and fittings and about 1 hour labor. the stocker will cost 150 to 200 and about 30 to 60 min. The fass is around $500 -600 not real sure on that one or time, i haven put one on before ( just herd the BIG -BOYS TALK) clear the codes and see if they come back, but I think your OK
DeweyND
Jan 9, 2009 08:28 PM
20014x4
Aug 17, 2006 04:45 PM
snowshoebrue
Jan 22, 2006 01:09 PM
jt_gladstone
Aug 9, 2005 11:24 AM
Shawnntx
Aug 4, 2005 10:42 PM
