i found the leak
Old Sep 3, 2006 | 05:06 PM
bigreddiesel's Avatar
i found the leak
i had a problem with a fuel leak a drop of fuel a secound feel from the bottom bolt on the injection pump. i just replaced the gov spring and the throttle shaft seal. the pump vent line is leaking my question is it is a replacable part or can i repair with rubber hose. thanks guys
Old Sep 3, 2006 | 05:27 PM
Have you replaced the washers on the return banjo? A fresh set will probably fix 'er right up.
Old Sep 3, 2006 | 07:49 PM
it is not leaking from there. it is leaking right before the first clamp that holds it to the engine
Old Sep 3, 2006 | 07:53 PM
i was trying to find out if i can remove this line with the pump still in place and if this is a high pressure line
Old Sep 3, 2006 | 08:52 PM
It's going to be hard to get it out, you will probably have to pull a few injection lines. There is no pressure to speak of in the return line. Diesel rated fuel hose is an acceptable repair.
Old Sep 4, 2006 | 12:00 AM
is there anything i should know about before i pull some injection lines. or is it just un bolt and remove.
Old Sep 4, 2006 | 06:01 AM
Don't bend them. You should be able the get them off in groups of 3.
Old Sep 4, 2006 | 08:07 AM
great thanks a lot guys i can't to drive my truck today
Old Sep 4, 2006 | 03:58 PM
the lines were a ***** and i repaired the fuel leak only to find more that i had already fixed. see other post
blackram2500
Apr 29, 2010 04:36 PM
SmokinFive9 4x4
Feb 27, 2005 04:48 AM
HorseHauler
Oct 12, 2004 10:53 PM
signature600
Aug 7, 2004 05:59 PM
DieselDaze
Feb 4, 2003 07:07 PM
