Sponsored by:
Sponsored by: CARiD
Found a Sneaky Oil Leak!
Old Feb 1, 2003 | 06:47 PM
DieselDaze's Avatar
I Found a sneaky oil leak this morning, so I thought I'd share my findings with everyone.<br>I dont know if the 24V's are different, if this post is not in the right place, sorry Gonzo, please move to the appropriate place.<br><br>Anyway, the oil return line from the turbo drops down and tucks between the oil filter and the block. (12V engine. May be different on 24V's?).<br>This return line is a metal tube. However, between the oil filter and the block, it goes through a rubber fitting into another metal tube. <br>This rubber fitting has two hose clamps (One for each metal tube).<br>Both of the hose clamps were lose, lose enough to be leaking a little oil. <br>It was difficult to get to without removing the oil filter, but could be managed with a screw driver and a box end wrench.<br><br>I dont want to imagine how much oil would be lost if one or both of the hose clamps let go while driving down the freeway.<br><br>Just something to check out.<br><br>Rich
Old Feb 2, 2003 | 07:30 AM
Alan_Reagan's Avatar
Re:Found a Sneaky Oil Leak!
Good tip. Thanks.
Old Feb 3, 2003 | 12:46 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I saw this on my truck when I removed the turbo, I can not imagine how you managed to tighten those clamps, let alone see them with the turbo in place!<br><br> Thanks for the tip Rich!
Old Feb 3, 2003 | 02:59 PM
DieselDaze's Avatar
I was lucky.<br>The top hose clamp could be reached with a long screw driver. <br>To tighten the bottom clamp, I had to use a combination wrench and used the box end to tighten the clamp. However, in order to gain access to the clamp, I had to crawl under the truck and approach the clamp from the bottom.<br>As mentioned, both clamps were very lose.<br>
Old Feb 4, 2003 | 10:44 AM
BIG&BAD's Avatar
good info
Old Feb 4, 2003 | 07:07 PM
Redleg's Avatar
Have my turbo off now, greasy mess down there. I was planning on replacing that connection. Had to remove the filter as well.
Homestead
ABDTR #5
24
May 13, 2011 12:08 PM
blackram2500
Apr 29, 2010 04:36 PM
roxxx
ABDTR #5
Aug 1, 2009 10:44 PM
