How much play is to much??
How much play is to much in my turbo? I am talking about up and down play.
I went from NH to Az and back and in Oklahoma the turbo started to whistle. I checked it and it had about 1/8" of play. I had to continue on so I did. The dealer just put this one on 3000 miles ago. They 3 day aired me another turbo and it has as much play as the one that is on the truck.
I always thought that the shaft should be tight (play measured in thousands of an inch). I can measure this one with a tape measure, and when it gets hot it gets looser. I also can not get my boost over 18 now. Are all of these turbo's that loose or do I have two bad ones?
Thanks
Eric
Thanks
Eric
Thanks wanna
Now that I think about it I thought it sounded like it was coming from the drivers side. If I have a leak on the drivers side that would explain my noise and lack of boost. I will check it in the AM
I got around today to look for my leak. It is leaking at the head where the flat plate bolts on right below the pre-heater. The gaskets will be here in the morning. Does anyone know if I can do this job without removeing the injector lines?
cincydiesel
May 19, 2009 09:39 AM
hellotbone
Aug 5, 2003 11:18 AM
