how do I purge air from fuel system
Old Mar 9, 2003 | 07:50 AM
Bobp's Avatar
I managed to air lock my 24 valve 2001 Cummins. I had water in fuel, and apparently drained to much and didn't read the manual aboput bumping the starter. So am now air locked. I did fill the filter housing with fuel, but the ring didn't seal good and allowed more air in. So it started momentarily, but that was it. I now have a new filter and O ring, but have a feeling I need to purge the air out of the lines. How, do I go about doing this?
Old Mar 9, 2003 | 07:59 AM
AlpineRAM's Avatar
Re:how do I purge air from fuel system
BobP- I assume your lift pump is good.If this doesn't work chances are good that your lift pump is shot.<br><br>Step 1: Mount fuel filter<br>Step2: Open banjo bolt on the line from the filter to the inj.pump.<br>Step3: Have somebody turn the key or bump the starter to have the lift pump running- do so until you get pure fuel out of the banjo.<br>Step4: Tighten banjo<br>Step5: crack open 1 injector line at the head <br> <br>Be CAREFUL- this step involves HIGH PRESSURE DIESEL <br>Bump starter again until fuel comes out of the injector line.<br>Tighten injector line<br><br>Step6: Attempt to start, not longer than for 15secs, let starter cool and repeat.<br><br>HTH<br><br>AlpineRAM
Old Mar 9, 2003 | 08:30 AM
tombonnieb's Avatar
Hello Bob, We air locked my sons changing the fuel filter not to long ago on his 2001. You can remove the fuel filter and fill and reinstall (it takes a 1 1/8 socket) if the filter assembly is dry.Turn on the key until you hear the lift pump, if no noise bump the starter until you hear the lift pump. Follow the fuel line down from the bottom of the fuel filter to the injection pump, you will see a black cap that looks like a air valve stem. This is the schrader valve take the cap off and depress the valve like you would be letting air out of a tire until fuel flows. Shut off ignition and restart cranking hard to allow any remaining air to pass thru the injectors. We only had to let the air out of the schrader valve to restart. Hope this helps
Old Mar 9, 2003 | 12:59 PM
Bobp's Avatar
I will try the shrader valve approach. I believe the lift pump is OK, as I heard it running after I bumped the starter. I am assuming that I try to release the air while the lift pump is running.
Old Mar 9, 2003 | 02:02 PM
Bobp's Avatar
Ureka!, I got it running. I bled the shrader valve, and also had to remove the fuel line to the #1 injector, but that got it going. Thank's for the help
Old Mar 10, 2003 | 07:51 AM
tombonnieb's Avatar
Hello Bob, Well I am glad to hear you got it started, It sure sends a bit of panic when it dies.My sons 2001 always gives us trouble. My 2001 has no problems when I drain or change the filter. Good luck on future filter changes.
Old Mar 10, 2003 | 03:48 PM
AlpineRAM's Avatar
tombonnieb: <br><br>Maybe a stupid question: Did you check the lift pump on your sons truck? <br><br>AlpineRAM
Old Mar 10, 2003 | 07:43 PM
tombonnieb's Avatar
That is a good question, my sons truck is still under warranty so I will have him check it out at the dealer. We have changed his twice it hesitated the first time and the second time it air locked. I will share the info with him. Thanks
Old Mar 10, 2003 | 10:23 PM
Scubasteve's Avatar
I had the same problem and found the bypass vale fell out inside the lift pump!! The pump sounded fine but wouldn't build pressure to save itself. I put a new lift pump on and found it would flow a fair amount of fuel out of the shrader valve and once that was done she started right up.<br><br><br>I will bet money the lift pump is junk.<br><br>Jason
Old Mar 13, 2003 | 03:08 AM
AlpineRAM's Avatar
Scubasteve: <br><br>My liftpump had the same problem. The valve was gone. So I had sound but no pressure. Now I have a Holley blue in the frame rail.. ;D<br><br>AlpineRAM
oliver92
Sep 14, 2009 08:32 PM
Crimedog
Apr 25, 2008 08:02 AM
RocketJohn
15
Apr 23, 2007 09:38 PM
Moose10
Mar 3, 2007 03:59 AM
Dodgezilla
Apr 26, 2006 01:51 PM
