how about some help please,anyone desprate
Old Feb 10, 2009 | 06:10 PM
ratman46's Avatar
i asked this question but no one could answer. so i will try again. my 2003 48re tranny lite is popping on once and a while tranny seems fine .it comes on right after i start up or 30 minutes later. please give me some kind of answer. thanks ratman.this is the temp lite
Old Feb 10, 2009 | 07:19 PM
GreyTD's Avatar
According to mine service manual the temp sensor is in the valve body and tied in with the governor pressure sensor. It could be failing if the lamp is coming on at startup. it's all I got.
Old Feb 10, 2009 | 07:21 PM
benroberts3605's Avatar
posible bad sensor, you need to have the codes pulled from it
Old Feb 11, 2009 | 01:25 PM
ratman46's Avatar
thanks , is this part replacable. or can i get to it with taking the tranny apart.
Old Feb 11, 2009 | 02:02 PM
GreyTD's Avatar
Yes it is replacable. It is attached to the valve body. Follow the wring harness, it should be the last item 4pin coonector side corner of valvebody. i don't know if it can be done without removing the Vb. Diagrams show you should be able to. Get a new one then you can see how it will attach. Sry can't be better help.
Old Feb 13, 2009 | 10:30 AM
ratman46's Avatar
thanks grey it will point me in the right direction apreciate the help
Old Feb 13, 2009 | 01:32 PM
04ctd's Avatar
search my posts, i did a "shudder" post,
and it has ~50 pics of the tranny & G'vnr solenoid.
the temp sensor may be the black plastic thing on the side.
hth?
Old Feb 13, 2009 | 02:48 PM
GreyTD's Avatar
ratman46
https://www.dieseltruckresource.com/...hlight=shudder
third picture the thingy on the right side with the red & brown wire is the piece you want.
Mini_Donkeys
Apr 19, 2007 12:21 PM
SuperiorRam
Mar 15, 2007 03:10 AM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
JKM
Mar 4, 2005 03:33 PM
