Help voltage problems
Old Mar 5, 2008 | 08:09 AM
NGA Ram's Avatar
I have noticed recently that my voltage has been staying low while the truck is running. At first I just thought this was my heater grid, but it stays low the whole time. The batts are new and the alt is new. I checked the codes and I have an active code for P0382 wich is relay 2 heater grid. Is this relay causing my heater grid to pull this much power. This morning my check guage light came b/c the voltage was so low.
Old Mar 5, 2008 | 08:21 AM
John Faughn's Avatar
Yes they can , disconnect the relay till you replace it .
Old Mar 5, 2008 | 08:24 AM
NGA Ram's Avatar
wich one would be #2
Old Mar 5, 2008 | 08:58 AM
NGA Ram's Avatar
Thanks I found a broke wire going to my relay i will see if that helps my voltage
imbodie
21
Jan 8, 2024 08:49 AM
Ada381
Aug 13, 2010 06:50 AM
OrangeCounty12V
13
Feb 22, 2008 11:55 AM
hamilton71801
Dec 2, 2007 07:32 PM
CrashCade
Aug 14, 2006 08:53 AM
