help truck wont run
Old Mar 16, 2010 | 12:19 PM
slowflyer2112's Avatar
help truck wont run
I have a problem. truck quit running, It was intermittent up until it finally quit.
Its a 2003 3500 and the codes that came up are;
628 and 2607 both of these have to do with low voltages. the transfer fuel pump has no voltage to run.
any suggestions on what to check to find the problem.
this truck is my brothers and I don't know it as well as my own which is a 2000
Please help
Old Mar 16, 2010 | 12:58 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
the pump (if still on the filter cannister and not changed to in tank version) should have a plug in connector you can check with a volt meter. Sometimes enough corrosion builds up to interfer. Spray it with ome contact cleaner and reattach. Check with voltmeter and see if it has good sterady voltage with key on (only works for a minute) let us know what you find out.
Old Mar 16, 2010 | 01:05 PM
madhat's Avatar
Administrator/Jarhead
Sounds like the lift pump has died. Is it still the stock one on the canister? I've been doing a lot of these lately... 0628 is the LP...
Does he have a FP gauge?
I can help out with a few options on this. Just let me know.
Old Mar 16, 2010 | 01:49 PM
lift pump is on the canister and was replaced six months ago, there is no voltage at the pump (already checked with meter) fuses are checking fine. codes say low or no voltage.
Old Mar 16, 2010 | 02:06 PM
loya 3500's Avatar
well i had that the low or no voltage codes be for i got my truck fixed and it was the map censor had a bad connection... i replaced the lift pump be for hand too
Old Mar 16, 2010 | 02:08 PM
did you truck quit running or stall? do to no fuel?
Old Mar 16, 2010 | 02:26 PM
loya 3500's Avatar
yes sir. for Example one day i stoped at a stop light went to take off pushed the gas and the trucked bucked and died as i costed to the shoulder truck would not start for about 10 min and then it started and i went on down the road.... are your gauges working on the dash?
Old Mar 16, 2010 | 04:10 PM
thanks, I'll check it out
Old Mar 16, 2010 | 09:41 PM
All connections seem fine, this is a california truck so no corosion.
Does any one have a schematic and or trouble shooting guide for checking this problem? Maybe a pdf file the factory manual?
Old Mar 16, 2010 | 09:43 PM
madhat's Avatar
Hang on, let me look for it... It's an 04 manual, I can get you close, at least...
Old Mar 16, 2010 | 09:52 PM
madhat's Avatar
Symptom List:
P0541-LOW VOLTAGE ON THE #1 INTAKE AIR HEATER RELAY
P2607-LOW VOLTAGE AT THE #2 INTAKE AIR HEATER RELAY
Test Note: All symptoms listed above are diagnosed using the same tests.
The title for the tests will be P0541-LOW VOLTAGE ON THE
#1 INTAKE AIR HEATER RELAY.
When Monitored and Set Condition:
When Monitored: When the ignition is on.
Set Condition: When the signal from the #1 intake air heater output does not match the
signal from the #1 intake air heater feedback.
Set Condition: When the signal from the #2 intake air heater output does not match the
signal from the #2 intake air heater feedback.
POSSIBLE CAUSES
LOOSE CONNECTION
SIGNAL CIRCUIT OPEN FROM RELAY TO ECM
SIGNAL CIRCUIT SHORTED TO BATTERY NEGATIVE
ECM
INTERMITTENT CONDITION
TEST ACTION APPLICABILITY
1 Ignition on, engine not running.
With the DRBIIIt, actuate the #1 Intake Air Heater.
Can you hear the Relay clicking?
All
Yes ! Go To 2
No ! Go To 3
2 While the relay is clicking , wiggle the wiring harness and connectors.
Does this interrupt the clicking?
All
Yes ! Repair the poor connection.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
No ! Go To 3
148
DRIVEABILITY - DIESEL
3 Turn the ignition off.
Remove the Intake Air Heater #1 Relay.
Check connectors - Clean/repair as necessary.
Measure the resistance between the signal and return posts of the intake air heater
relay.
Is the resistance between 15 and 25 Ohms?
All
Yes ! Go To 4
No ! Replace the Intake Air Heater #1 relay.
4 Disconnect the ECM harness connectors.
Measure the resistance of the intake air heater relay signal circuit between the ECM
connector and the intake air heater relay connector.
Is the resistance less than 10 Ohms?
All
Yes ! Go To 5
No ! Repair the open signal circuit from PDC to ECM harness connector.
5 Measure the voltage between the signal circuit of the intake air heater relay and
battery negative.
Is the voltage greater than 1 volts?
All
Yes ! Repair the signal circuit shorted to Battery negative.
No ! Go To 6
6 Reconnect the ECM harness connectors.
Disconnect the intake air heater relay signal wire and use a jumper to connect it to
battery negative.
Turn the ignition on.
With the DRBIIIt, read DTCs.
Did DTC P0542 set or P2608?
All
Yes ! Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
No ! Replace the ECM.
149
P0541-LOW VOLTAGE ON THE #1 INTAKE AIR HEATER RELAY —
Continued
Symptom:
P0628-LOW VOLTAGE DETECTED AT THE FUEL LIFT PUMP
When Monitored: While the key is on.
Set Condition: The voltage detected on the Fuel Lift Pump is above a calibrated value for
a calibrated amount on time.
POSSIBLE CAUSES
LOOSE CONNECTION
GROUND CIRCUIT OPEN
LIFT PUMP SHORTED TO VOLTAGE
LIFT PUMP
ECM
1 With the DRBIIIt, in system test actuate the lift pump.
Does the lift pump run?
All
Yes ! Go To 2
No ! Go To 3
2 Lift pump actuation still running.
While the lift pump is running, wiggle the wiring harness and connectors throughout
the circuit.
Does this interrupt the pump operation?
All
Yes ! Repair the loose connection.
No ! Go To 3
3 Disconnect the ECM harness connectors.
NOTE: Check connectors - Clean/repair as necessary.
Measure the resistance of the lift pump (K62) supply circuit between the ECM
harness connector and the lift pump harness connector.
Is the resistance less than 1 Ohms?
All
Yes ! Go To 4
No ! Test Complete.
181
4 Measure the resistance of the ground circuit between the lift pump connector and
battery negative.
All
Yes ! Go To 5
No ! Repair the open ground circuit.
5 Measure the voltage between the supply and ground circuits of the lift pump
connector.
Is the voltage greater than 1 volt?
All
Yes ! Repair the lift pump circuits shorted to voltage.
No ! Go To 6
Connect a jumper wire between the (K62) supply circuit and ground circuit of the lift
Did DTC P0628 set?
All
Yes ! Replace the lift pump.
182
Old Mar 16, 2010 | 10:17 PM
Awesome, do you happen to have the diagram for the location of some of these check points, I couldn't find the relay in the fuse box.
Thanks
Old Mar 16, 2010 | 10:24 PM
madhat's Avatar
I do, but it would take me forever to copy and paste it...
I'll send you a PM...
Old Mar 16, 2010 | 10:52 PM
Thanks
Old Mar 18, 2010 | 09:56 AM
loya 3500's Avatar
did you fined a fix yet...?
Sarajaye
25
Feb 26, 2013 03:00 PM
12valve1/2ton
13
Nov 23, 2011 02:09 AM
Stroked-Z
Oct 4, 2008 11:28 AM
coontz0473
Oct 4, 2006 02:48 PM
nvillagrana
13
Aug 20, 2006 05:13 PM
