HELP! Transmission problems. Starting in 3rd, and TC issue. TRIP TOMORROW!
Old Apr 15, 2009 | 10:13 AM
ienjoydrifting's Avatar
Truck - 03 dually, standard output. only mod is a TC lockup switch.
Ok so the tranny worked fine but it was due for a flush and filter. So i got a new filter and atf-4 and did the flush. For 3 days after the flush the trans worked perfect.
Last night the truck would not shift out of 1st gear. The revs would hang at 2500rpm or higher for several seconds, sometimes almost 10 seconds! Then shift and the rest were all good.
This morning I leave for work and its taking off in 3rd gear. I am sure its third because I can drop it into (2) on the shifter and it will take off easier.
Also now my converter locks in overdrive about 5mph later then normal. My TC switch still locks it when needed tho.
I have to take a 500 mile drive tomorrow so this has to be fixed today. What do I need DTR?
Old Apr 15, 2009 | 10:42 AM
Redliner's Avatar
sounds like gov pressure sensor going out. its going into limp mode. check fuse and relay first.
Old Apr 15, 2009 | 11:03 AM
what relay and fuse?
Old Apr 15, 2009 | 11:19 AM
Redliner's Avatar
trans relay...cant remember if there is a fuse too....
Old Apr 15, 2009 | 11:24 AM
checked them both. Tested GOOD.
Governor then?
What else should I replace along with it?
Old Apr 15, 2009 | 11:35 AM
DEALER WANTS 125 BUCKS! Geez
Old Apr 15, 2009 | 11:08 PM
oldblues's Avatar
hi
before you doo aany repairs read the codes wright them down and erase them and test deive it .
sometimes just erasing the codes clears it !
Old Apr 17, 2009 | 12:08 AM
Wound up taking the rabbit instead.
Ordered the PATC REgovenor kit. I went all out!
Mopar1973
Aug 26, 2012 08:40 PM
nvr-enuf
Apr 9, 2011 03:24 PM
ienjoydrifting
Apr 17, 2009 07:56 AM
Dave88LX
Dec 15, 2006 12:58 PM
