Help!!!! KDP getting fixed?????
Old Dec 22, 2006 | 09:28 PM
nates90's Avatar
Hey guys....I am going on vacation in 3 days with my truck. I am currently killing the KDP. It was sticking about about 1/8 inch...so im glad that im doing it. My question is how far does the pin normally go into the truck, far as i can go is flush....im going to start making my plate....so i will be on in about a hour or so....so it would be awsome if someone would respond quickly.....Thanks guys
-Nate-
Old Dec 22, 2006 | 09:30 PM
They usually go a little past flush, but flush is OK.
Old Dec 22, 2006 | 09:56 PM
glenn-k's Avatar
Mine is a 24v manufacture date 8/98 --
Isn't that a gray area for KDP?
Old Dec 22, 2006 | 09:57 PM
Baja's Avatar
Mine was out about 1/8", and it took a hard hit with a drift pin to send it home, about 1/16" out. Going nowhere now.
Old Dec 22, 2006 | 10:23 PM
Nope. Every '98 build date truck I've done had the OLD case.
Old Dec 22, 2006 | 10:55 PM
fschiola's Avatar
You did still tab it, right?
Old Dec 23, 2006 | 08:39 PM
glenn-k's Avatar
Looks like one more project to check out.
Old Dec 24, 2006 | 01:06 AM
Lama's Avatar
Just did my 98 24Valve today. Had the old case. Pin was not coming out, and I tabbed it.
Pretty easy job, I found that a shaved down (on a bench grinder) 10mm box-end wrench works awesome for removing the 1 problem fan-bracket bolt behind the fan pulley.
Also, I put the truck in Reverse and chocked the wheels in ordeer to break loose the 4 harmonic balancer bolts.
Old Dec 24, 2006 | 02:49 AM
runamuk's Avatar
Wow, Nate you had to wait a whole 2 minutes for the correct information!!
All the rest is just icing on the cake!!
Nice job guys!!! Very well done!!! Thank you all!!
That's what I love about this site We never stop trying to fix it until it's fixed!!
Rick
Old Jan 3, 2007 | 11:57 AM
nates90's Avatar
Thanks guys, made it back from vacation monday, no problems at all.
Old Jan 3, 2007 | 01:04 PM
eyoung429's Avatar
Does the KDP issue pertain to 1st gens as well??
Thanks!
Old Jan 3, 2007 | 03:41 PM
Yes. It's not as common, but they have been known to drop out.
8Lug_hotrod
Apr 18, 2021 08:07 AM
Smokin96_12v
Oct 12, 2009 07:39 AM
jwtuc
14
Mar 22, 2004 08:35 PM
Captain Insane-O
Jan 12, 2004 11:04 PM
mikeh
0
Jan 20, 2003 01:15 PM
