help fuel leak
help fuel leak
help i got a fuel leak <br>i saw it this moring on my way to work <br>it look like it was coming from the fuel filter <br>i check the filter and was tight <br>it seems like like it only leaks when the truck is running <br>thanks for the help<br>bruce
Re:help fuel leak
Could be the rubber return line comming from pump.<br>Or the supply line but less likely<br>Or the drain in the bottom of filter.<br>All of the above a treat to change.<br>If you change line , do both of them while your there.<br><br> : Eddie : 8)
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
