Help Asap!!! 2007 Quit On Me On The Road!!!
Old Jun 13, 2009 | 11:57 AM
Racing_Joe66's Avatar
my 2007 diesel is all stock. i stoped at a rest area and shut the truck off. i come back out to start it and it won't start. i am getting a code po191. so i cracked a fuel line and there is fuel to the injection pump but nothing going to the injectors!!!!!!!
NEED HELP ASAP!!!!!!!
PLEASE
Old Jun 13, 2009 | 04:47 PM
J BODY's Avatar
Either the 5.9 or 6.7 that is for a fuel rationality issue. There is a flash to correct an erronious setting of that very code. "Cracking" a line on a common rail won't tell you much. Fuel volume is pretty low while cranking.
It is "cranking" correct?
Old Jun 13, 2009 | 08:03 PM
rich's Avatar
cracking wont do any good. if its a stick try push starting it, if not using gas vapors from a ag mite get it started. sounds like the injectors are not getting enough pressure to work could be several things just a guess tho
bandit1trucking
Feb 14, 2019 08:16 AM
IHMAN75
Jun 5, 2015 03:06 AM
bigboyky
Nov 5, 2006 11:02 AM
MoParr
0
Feb 16, 2003 01:26 AM
Mule Skinner
Nov 16, 2002 06:57 PM
