Help. with AC problem
Old Aug 6, 2009 | 12:08 PM
TexMexCowboy's Avatar
OK I just noticed yesterday that when my AC is on High it blow's out the bottom. I turned it to low and still doing it. just like if I had the heater on and blowing at your feet. I turned the temperature down a little and then it started blowing hot air out. I don't know what is wrong with it I checked fuses and they all looked fine. Can anybody tell me what else I can check on.
Old Aug 6, 2009 | 02:58 PM
Check for disconnected or broken vacuum lines under the hood. Follow the lines from the vacuum pump (between the power steering pump and the engine) and you will probably find it pretty quick.
Old Aug 6, 2009 | 03:13 PM
now that you say that I think I remember a line that was loose down there. would it be running by fuel filter canister?
Old Aug 6, 2009 | 03:30 PM
Yeah, they pass through that area.
Old Aug 6, 2009 | 03:38 PM
crucescrawler's Avatar
I melted one down close to my turbo on the firewall that started leaking. Check that out.
Old Aug 6, 2009 | 04:47 PM
guys thanks I am going to check it out and see if I have anything loose or broken down there. I knew yall could help me.
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
