HELP - 07 Mega died in middle of Wyoming!
Haha, yeah I was thinking they might have accidentally used a Toyota I-Force cam.
It's really weird considering that there's no drag on the cam like an injection pump and it never sees over 3000 rpm.
Dodge is deciding whether to replace the cam or the entire engine right now so I abandoned the truck here and am flying back home... or was planning to fly back, now my flight got canceled on account of a snowstorm in Salt Lake City and I'm stranded at the airport. It has been a tough week lol.
I'll be in RS until 4am tomorrow then I leave with the wrestling team to Reno. Once again if you need anything give me a call. 389-0531.
We could get you a free ride to the SLC airprort tomorrow morning if nothing works out today. That airport would be better to be stuck in than the one here!
A camshaft just doesn't break like that! There had to be some serious drag on it such as a seized bearing. And I would be surprised if you still have 24 straight valves and 6 pistons without holes in the top of them. Insist on a new engine unless they can prove to you there is no collateral damage. Good luck and please keep us posted.
An interesting read on DonM's site, about the Helix camshafts (an upgrade). Look at the paragraph for the 2nd picture. Apparently, it is common enough to engineer around it.
J Body, I had the truck's oil changed just 500 miles before the camshaft broke at a Jiffy Lube while I was on the road. I requested Rotella T because that's what we use in our heavy fleet and it's a high quality oil. I wasn't watching them close enough to see if they really did use it but they definitely charged me for it. I made them use the Mopar filter I had in the truck.
Buying the old engine is a good idea... having a used CR cummins laying around at the yard couldn't hurt. Maybe I could get it rebuilt, port out the heads, throw a Helix 2 and some springs in her, get it fire ringed.
It would be nice to see a picture of the cam. It would also be interesting to see what caused it to break? Breaking at the front either tells you something further down the shaft either bound up breaking it or a possible defect is the cam casting itself. As far as I know there is only 2 cam bearings in that motor. At least the 12 valve motors only had 2. Thats an awful long shaft. The spring pressures are light. If oil was considered to be at fault you would think there would be some scuffing or gauling in some areas. As J-Body said he had heard of another breaking. Might be a coincidence on the rotella and cam failure as a big majority of diesels run the rotella. Bummer no matter what caused it.
My coworker asked me “what type of oil should I run in my 2000 Dodge 5.9 24 valve diesel and should I use an additive” I said “heck I do not know, but I will post it on "XXXX” He is concerned because the local Dodge dealer recently had to order new cam and lifters for 2 different people. They are blaming the failures on the new Rotella formula. What do you folks recommend?
Just find it interesting and I guess since my truck is filled with Rotella, just as it has been for years, I am in test mode
I would urge the original poster to find out "where" the cam broke, and see what the break looks like: "twisting"?, clean break?, and "where" did it become two? Of course the odds are pretty great that they won't pull apart the old engine that far. I know I wouldn't on warranty time. Out with the old....in with the new.
Yes, there are only 2 bearings, one in front and one at rear, however it also rides on the block at points in between. Unless there is definate signs of siezure, I would definately suspect a defect in the cam itself.
I have to wonder what the dealer will do with the engine.
I would definately look into buying it, and if they "can't" maybe CASH would make it doable. (in a situation where Dodge would say it has to be scrapped) Cash might make it stay NEXT to the dumpster so to speak.
02dodge2500ctd
13
Dec 11, 2008 07:29 AM
jwhip
Nov 26, 2006 12:34 PM
