Headlight problem
Old Jan 20, 2009 | 09:35 AM
precision151's Avatar
Headlight problem
I turned headlights on this morning on my 99 2500 and the dims wouldn't work just the brights. Any help would be appreciated. thanks Jr.
Old Jan 20, 2009 | 09:41 AM
John Faughn's Avatar
Do you have access to a multi meter & familiar with using ?
Unplug the head lights , check continuity of the filaments in the head lights , then see if power is getting to the low beam .
After that it could be the switch in steering column , do a search here , for wiring diagrams , to find you specific truck , someone should know that model & give more info soon .
Old Jan 20, 2009 | 09:42 AM
infidel's Avatar
Disconnect the batteries and spray electronic cleaner at the base of the multifunction switch (turn signal) while working the dim/brights back and forth.
Old Jan 20, 2009 | 09:44 AM
thanks for the info. found another thread with some info too. thanks again
mtdoragary
Nov 7, 2013 08:31 AM
Homestead
16
Jan 6, 2006 11:13 AM
jlipskoc
Oct 24, 2005 01:16 PM
m batterson
Dec 22, 2002 10:20 AM
