headlight problem
Old Dec 22, 2002 | 10:04 AM
m batterson's Avatar
headlight problem
hi all,<br>i will try to explain this the best i can.<br>when coming home last night,i had the high beams on.a car came from the opposite direction. when i pulled the lever to dim the lights i had no lights.low beams were completely out.i pulled the lever again and the high beams came back on.pulled it again and no low beams.i found out i was able to get the low beams to come back on by pulling the lever to activate the high beams and holding it for a few seconds and then releasing it.do i have a relay problem,or a bad turn signal,high beam arm.the recall for the headlight switch was done sometime back.<br>thanks for any and all suggestions.<br><br>mike<br>
Old Dec 22, 2002 | 10:20 AM
Stamey's Avatar
Re:headlight problem
Sounds like the dimmer switch sticking to me.<br><br>Chris
mtdoragary
Nov 7, 2013 08:31 AM
Homestead
16
Jan 6, 2006 11:13 AM
JD730
Jan 6, 2006 09:39 AM
jlipskoc
Oct 24, 2005 01:16 PM
