Guess my fuel guage is toast
Old Mar 9, 2006 | 06:18 PM
megajoltman's Avatar
Thumbs down Guess my fuel guage is toast
Been driving about 150 miles on this tank and the guage is still on the full mark shut the truck off goes to E start it and it peg's to just over full any ideas beside the sender?
Old Mar 9, 2006 | 06:41 PM
Hipshot's Avatar
That happened to me too 1st time I filled the truck. I tried everything to shake it loose. No dice. Till the next time I filled it, it worked fine again! And I haven't seen the problem since! If it becomes a habit well then I'll drop the tank and repair the sensor. But sorry to say... it IS the sensor.
Old Mar 9, 2006 | 06:48 PM
Man happen's on my 3rd fill up since buying it
Old Mar 9, 2006 | 09:09 PM
DMH's Avatar
DMH
That happens to me everytime I fill up. But then, I fill it to the neck and then it takes about 150 miles for the guage to start dropping.
I have never had it stick in the full position, yet.
DMH
Old Mar 10, 2006 | 07:25 AM
Rauschbo's Avatar
Before I had my sender replaced (thanks to a non-attentive semi-driver), I would get aberrant readings after hard braking or hard cornering; This was cured with a follow-up hard braking event - probably needed to slosh things around to break free whatever had become all wadded up?
Old Mar 10, 2006 | 01:00 PM
Hmm maybe some biodiesel time, one other thing is I used Premium Diesel Fuel Conditioner in the first 2 tanks skipped it for this one and I don't think it was ever used by the first owner
Old Mar 10, 2006 | 05:58 PM
rockwithjason's Avatar
The sender for the fuel level is about $50, you can get it with out the whole in tank module.
Old Mar 21, 2006 | 06:06 AM
Barry Smith's Avatar
It's probably easier to just lift the bed than drop the tank.
Old Mar 21, 2006 | 07:40 AM
Dr. Evil's Avatar
Depends on how you drop the tank I guess. Throw a chunk of plywood under the tank (hopefully its almsot empty) and lower it with a floor jack. To me dropping the tank is a lot easier than lifting the bed.
Old Mar 21, 2006 | 10:50 AM
RCW's Avatar
RCW
Do not waste you money on a new, and just as prone to wearing out as the old one, sender if it is the hinge pin that is shot. Pull the old sender and take a look at the hinge pin, it will likely be pulled out from one side and bent into a bind. That is what nearly always fails. You can carefully clip out the old hinge pin and then replace it with a chunk of aluminum welding rod bent over at both ends. The total cost of the fix will be about $2, and will last you forever.
Old Mar 21, 2006 | 02:37 PM
It started working again on the next fill
Old Mar 21, 2006 | 02:39 PM
Cool fix if goes completely I'll try that
Old Mar 22, 2006 | 12:08 AM
That's a good idea. I just kept thinking about 34 gals. of diesel landing on my chest at 8lb/gal.!
bigragu
Jan 24, 2006 11:16 AM
Lightman
31
Nov 21, 2003 02:14 PM
goldenears
Jul 1, 2003 02:01 PM
Extreme Diesel
Dec 6, 2002 11:24 AM
