Grinding
Old May 14, 2006 | 12:08 AM
TxnBorn88's Avatar
Grinding
i have a 2001 3500 dually 6 speed 2wheel drive. It seems that when i start off from a stand still i hear a sort of grinding noise only at about 800 rpm and then once it passes that point it is gone. any ideas thanks for the help
Old May 14, 2006 | 07:48 PM
bmoeller's Avatar
How many miles on the clutch? May be the rivets on the cltch disc scrapping the pressure plate or flywheel.
Old May 14, 2006 | 10:34 PM
TxnBorn88's Avatar
I have adsolutly no idea. Is it pretty hard/expensive to replace the clutch and flywheel
Old May 14, 2006 | 10:37 PM
torquefan's Avatar
I'm thinking it may be a worn/dry pilot bearing. They typically growl when you slip the clutch to start out from a stop.
Old May 29, 2006 | 09:20 AM
drumrunner's Avatar
My 01 2500 6-speed has done it in 2nd gear (off and on) since around 80K. Dealer had no idea what it was, checked the tranny and the clutch. At 128K and it still does it, no better but no worse either. Only does it in 2nd never 1st.
cLAYH
Feb 6, 2004 10:59 AM
cmckinney
Oct 9, 2003 12:06 PM
dodgeman01
May 5, 2003 10:28 PM
yorkpaddy
Mar 4, 2003 07:12 PM
angus
Feb 6, 2003 09:16 PM
