Full tank of unleaded
Old Dec 7, 2008 | 11:22 PM
havakey's Avatar
I put 30 gallons of unleaded into the tank. I drove it about a mile before I realized the mistake. The truck was running rough when I shut it off. I siphened out about 33 gallons out of the tank and plan to change the fuel filter. By the way I have the 6.7. Am I on the right track? What else should I do.
Old Dec 7, 2008 | 11:37 PM
BigIron70's Avatar
Cummins Guru
That's about all you can do other then fill the tank with diesel to dilute any remaining gas in tank. Should be OK then. Good Luck
Old Dec 7, 2008 | 11:44 PM
havakey's Avatar
Should I pull the tank and empty all the fuel out before refueling.
Old Dec 8, 2008 | 03:13 AM
catnfool's Avatar
these things are pretty forgiving- I run the nastyest garbage(waste motor oil) thru mine(a 5.9) with no troubles. If you got 30 gallons out, fill her up with #2, give her some additive, and let her rip!! She will forgive ya
Old Dec 8, 2008 | 04:00 AM
Old Hat's Avatar
put in 2 cycle oil to the diesel fuel
Old Dec 8, 2008 | 01:32 PM
dozer12216's Avatar
Replace filter and fill with PS or fuel. Loosen a fuel pressure line and crank. Trying to get as much gas out as possible and diesel into pump ASAP. The mix in tank is probablly O'K
Old Dec 8, 2008 | 10:28 PM
havakey's Avatar
Thanks to all. I have just got it all back together and seems to be back to normal. Few....... I suppose I learned my lesson on that one.
90 power ram
May 29, 2013 06:01 PM
redlineguy
15
Jan 9, 2012 09:15 PM
TXJosh
Mar 31, 2009 10:17 PM
EverydayDiesel
Jan 15, 2008 01:17 PM
phox_mulder
Jan 3, 2003 09:21 AM
