Fuel Shutdown Solenoid help
Old Mar 23, 2003 | 07:12 PM
Numero Uno's Avatar
I just replaced my Fuel Shutdown Solenoid, its working properly when you test it by hand, it stays in the up position. But when you start it normally it wont suck it up. Im gettin 12V from one side of the relay, but the other side shows 8V, is that right? or should it be 12 also? It also says it should be adjusted to 2.64in, can it be adjusted any shorter than that?<br><br>Thanks
Old Mar 23, 2003 | 07:14 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Fuel Shutdown Solenoid help
Where does it ground?<br>Could be a dirty, loose connection.
Old Mar 23, 2003 | 07:21 PM
Numero Uno's Avatar
Yeah I checked that, everything is clean. I was thinking maybe it needed to be adjusted shorter than the 2.64in? But I didnt want to put it shorter than the book said?
Old Mar 23, 2003 | 08:14 PM
doomgaze's Avatar
Check your relay and check the blue wire coming off your battery (there is also a fuse inside that wire you should check).<br><br>2.64 inches should be right. Mine is set at that.<br><br>I don't remember the voltage ratings on the wires
ndtguy1
Nov 27, 2003 09:48 AM
mechanic
24
Sep 26, 2003 11:46 PM
Fishinghaoliboy
Jun 28, 2003 08:33 PM
taz1456
Oct 27, 2002 09:01 AM
