fuel line pressure
Old May 17, 2008 | 01:26 PM
THE 0NE's Avatar
fuel line pressure
i am working on a 2000 ram with a walbro pump what is the fuel line pressure suppose to be before the lift pump? everything else on the truck is stock.
Old May 17, 2008 | 01:43 PM
madhat's Avatar
Administrator/Jarhead
Which walbro?
Old May 17, 2008 | 01:47 PM
THE 0NE's Avatar
i am not sure it was on the truck already. but it has a check valve system that looks like it bleeds pressure back to the tank if it gets to high. it has more power half power throttle than full
Old May 17, 2008 | 01:57 PM
madhat's Avatar
I believe that mine was factory set at 20 psi. Mine is a 392.
Have you changed your fuel filters? Is there a pre pump filter?
Old May 17, 2008 | 02:03 PM
THE 0NE's Avatar
no pump filter but there is the valve six inches from the pump i think that might be sticking open at wide open throttle. has anyone ever heard of that?
Old May 17, 2008 | 02:19 PM
madhat's Avatar
Do you have a FP guage?
What color is the bypass valve?
If it looks like this, you got gyped...
Old May 17, 2008 | 02:24 PM
THE 0NE's Avatar
ya i have a gauge it reads 20 at idle and drops like 10 psi when i step on it.
Old May 17, 2008 | 02:31 PM
THE 0NE's Avatar
the valve is brass
Old May 17, 2008 | 02:51 PM
madhat's Avatar
Ok, so it's the right bypass.
Is 10 as low as it goes?
I run mine at 10 PSI, I can suck mine down to 5 psi when everything is set to kill.
Where do you take your fp reading at?
Old May 17, 2008 | 03:09 PM
THE 0NE's Avatar
i think it is from the lift pump a port off of it
Old May 17, 2008 | 03:10 PM
THE 0NE's Avatar
if i floor it it bogs than i let out a bit and it takes off
Old May 17, 2008 | 03:19 PM
madhat's Avatar
Hmmm... as long as you have positive pressure, you should not be having problems related to FP... I could run mine down to 0 before it would stutter.
2nd gen... right? Could be a VP issue...
Have you changed your Fuel filter?
Any codes?
Old May 17, 2008 | 03:45 PM
THE 0NE's Avatar
no codes and the vp was changed two weeks before i got it like 4 weeks ago and yes to the filter i am lost
Old May 17, 2008 | 03:52 PM
johnh's Avatar
check air filter
dodgeguy71
17
Jan 19, 2012 12:52 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
Sixpack73
Aug 21, 2007 10:51 AM
Flatty
Jan 5, 2005 02:50 PM
