Fuel leak on bottom of injector pump
Old Mar 13, 2008 | 08:10 PM
Bob Hawthorne's Avatar
Smile Fuel leak on bottom of injector pump
Hi,
I have a 1993 Dodge D250 with a Cummins 5.9 litre engine. I found fuel leaking from the bottom of the fuel injector pump. Upon further inspection I discovered a plug missing on the bottom of the pump. I'm not sure if this is a drain plug or exactly what it is. It's a bad enough leak that I won't use the truck until a fix is found. Anybody got an idea what I need and where I can get the part?
Many thanks to all, Bob Hawthorne
Old Mar 13, 2008 | 09:21 PM
DiezelSmoke's Avatar
Probably a weep hole, which means it has a bad seal. I'm guessing it is at the end of the pump that goes into the engine.
Old Mar 14, 2008 | 08:01 AM
Smile Thank you for feedback
The hole is about in the middle of the bottom of the injector pump. It is threaded and looks like it could be 3/16 pipe thread. I'm afraid to put a pipe plug in there without knowing for sure. Thanks for the help, Bob Hawthorne
Old Mar 14, 2008 | 04:27 PM
The fuel is not coming out of that hole. It is probably coming from the timing piston cover on the backside of the pump. It's an easy fix - after you take the pump off the truck.
Old Mar 15, 2008 | 12:48 PM
rattlerbob5.9's Avatar
If you are loosing a good amount of fuel it likely is the timing piston cover has come loose and blown or pushed out the oring under the cover. I fixed one 3 years ago for a guy that pumped out 3/4 of a tank of fuel in 25-30 miles left a good trail behind cleaned all the undercoating off and still was running fine .
Like wanna said easy fix once the pump is off that is the only way you can get to it.
Old Mar 15, 2008 | 03:41 PM
Smile Thank you!
Many thanks for the feedback. I'll take you advise and get the pump off and have a look. I'm glad I found this site. You guys are great!
Thanks, Bob Hawthorne
Old Mar 15, 2008 | 08:22 PM
Fill in you signature so we know where you are and what your truck is .
If you are doing this yourself be careful not to drop anything down inside the timing cover and get the engine up to TDC and lock the pump before you remove it also make sure not to get any dirt in the pump or fuel system .
bflood
Dec 29, 2019 06:05 AM
HelenaTDI
Mar 28, 2009 09:56 PM
tilyn62
24
Sep 30, 2005 07:08 AM
