Fuel guage sticking on full
Old May 14, 2004 | 09:37 AM
poogan's Avatar
I have a 1999 2500 and for the third time the fuel guage has suck on full. The first time it was under warranty but the last two times I paid. Any one having the same problem.
Old May 14, 2004 | 09:46 AM
Diesel Dave's Avatar
I have heard of some guys having this problem if they fuel up with the nozzle on full blast. I think they said it can bend the fuel level sender.
Old May 14, 2004 | 09:49 AM
poogan's Avatar
You may be right on that, it was the sender they replaced....and it probably was me because I pump the fuel....Thanks for the reply
Old May 14, 2004 | 10:04 AM
RATTLINRAM's Avatar
Thumbs down I think the sending units are junk,,,,
Don't feel bad poogan,
I ran mine out not too long ago when my gauge was still showing almost 1/4 tank. (related thread here)
I'm not trusting mine anymore without checking the trip meter to varify the mileage. I have read posts of folks who have removed their old senders and repaired them and said that they have not had the problem happen again. You might try and do a search of fuel level senders.
I'm hoping to get the chance to pull mine out and see what exactly went bad on it to determine if it can be repaired. From what I've read,,,,,,,, it is a very common failure in the CTD's as well as the gassers.
Old May 14, 2004 | 11:31 AM
JAXFL1's Avatar
Smile Add me to the list ... BUT
I had the same problem about 2 weeks ago, but then it started to go down. It stayed on FULL for 4 days in a row. But the problems seems that I went from 12MPG in town to 15MPG on that tank and the needle just did'nt move for awhile. Maybe that is the "problem?" with yours.
Old May 14, 2004 | 01:34 PM
infidel's Avatar
When they stick on full sometimes a swift kick or a rubber mallet to the fuel tank will unstick it.
I don't see how filling too fast can effect it since the sender and float is enclosed in the tank module, fuel can only get at it from the bottom.
Filling the tank too full can cause it to stick on full though.
Probably the reason why the manual says to only fill to the second automatic nozzle shutoff.
Old May 14, 2004 | 01:47 PM
RustyJC's Avatar
Full blast on the big rig fueling nozzles has been known to take them out mui pronto!
Rusty
Old May 14, 2004 | 07:24 PM
MARKY MARK's Avatar
I had the same problem about a month ago. I got under the truck and kicked the hell out of the tank like infidel mentioned above. That took care of it. Good luck.
redlineguy
15
Jan 9, 2012 09:15 PM
13bdarren
Jan 27, 2009 12:39 PM
West Coast
Jul 4, 2007 10:25 AM
j
Nov 14, 2003 09:38 PM
