fan clutch
Old Sep 22, 2005 | 12:33 AM
mikal711's Avatar
fan clutch
i noticed wires hanging down in the front of my 04 4x4 the fan cut the wires to the thingamig attached to the fan is it safe to drive to get away from hurricane the only thing i noticed it was running about 200 temp and the ac semmed to cycle alot if i keep a eye on temp is it safe to drive?
Old Sep 22, 2005 | 12:50 AM
infidel's Avatar
Probably safer than hanging around for Rita.
Just don't use the A/C and watch your temps.
Might want to think about getting out early to avoid bumper to bumper if it isn't already too late.
Old Sep 22, 2005 | 10:11 AM
doorguy's Avatar
You have an electronicly controlled viscous fan drive, ( the engine control module controls the fan). Looking at your options I would get out , keep a close eye on the temp. Good luck
Old Sep 22, 2005 | 07:02 PM
J BODY's Avatar
As bill said, you can drive it, just watch the temp. If you get moving at a decent highway speed it's ok to use your a/c too as there will be air flow across the condensor. Just be sure to shut it off (a/c) if you get mired down in traffic or come to a stop.
Old Sep 22, 2005 | 07:08 PM
Haulin_in_Dixie's Avatar
Earlier this year I drove mine without a fan for a few day with loads. Just have to watch stop and go traffic and the air conditioner. Don't let it overheat.
Old Sep 22, 2005 | 09:02 PM
mikal711's Avatar
thanks guys i madee it too jufkin tx at daughters house but im not so sure just how safe it is here but its got to be better than houston, this is one bad mama, any ideals how much the fan is , or do i just have to replace the clutch?
Old Sep 22, 2005 | 10:42 PM
J BODY's Avatar
Only clutch assy's I've put on were warranty, but I imagine with the technology involved......and being it's on a diesel...it's very expensive. If you end up doing it yourself I would take a piece of sandpaper and smooth the edges of the plastic fan. Check the edges and you'll see what I mean....I cut myself BAAADDD on that stupid thing.
Old Sep 23, 2005 | 09:59 AM
infidel's Avatar
If you aren't under warranty why not just splice the wires back together?
It sounds like the only problem may have just been a tie down that came off and allowed the wires into the fan.
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
