95 12v won't start, just replaced transfer pump
Old Sep 23, 2005 | 01:27 PM
falcone's Avatar
I have a 95 12v and i just put on a fuel transfer pump. It ran with the old pump in but it was leaking fuel out of the weep hole. so i got a pump from the local cummins dealer. i bleed the low pressure line on top of the fuel filter housing and tried starting. wouldn't start. then i cracked the high pressure lines to the injectors and turned over the started to get the air out if there was any and it didn't seem like any air or fuel came out. it still wont start. does anyone know why it wont start.
Thanks, Falcone
Old Sep 23, 2005 | 02:10 PM
JD730's Avatar
I would check the fuel shutoff solenoid and see if its disconnected or not working. If it ran before and not now, I would check that first.
Old Sep 23, 2005 | 03:40 PM
apwatson50's Avatar
you still have air in the lines, make sure all the air is bled out of the filter and use the hand pump on the lift pump, then crack 3 injector lines and crank untill fuel squirts out. It'll probably run at that point, if not repeat on other 3 lines
gopokes
Jun 28, 2007 12:51 PM
none0000
Apr 24, 2005 08:20 AM
truckinjersey
Jan 30, 2005 06:52 PM
JRS240
Jan 29, 2004 08:06 PM
kd5wqk
Nov 3, 2003 02:06 PM
