Engine won't shut down!
Old Jan 30, 2006 | 08:19 AM
SHARPMACHINE's Avatar
Mine is working intermittenly as well ( starter solenoid ). Could it just need cleaned? If so how do you all do it?
thanks
Old Jan 30, 2006 | 09:39 AM
infidel's Avatar
thanks
If you're going to go though the hassle of cleaning it might as well replace the contacts.
Instructions here would be about the same to clean as to replace contacts.
http://www.fostertruck.com/contacts_install.htm
Both you guys who haven't addressed the starter sticking should take care of it ASAP otherwise you could be looking at up to $500 worth of damage.
Old Jan 30, 2006 | 09:50 AM
Are you sure, maybee I did not explain my problem well?? What I mean is that the solenoid is "sticking", The starter was recently rebuilt. The selonoid will slowly drop when I turn the key off. Sometimes when I try to start the truck it starts for about a second then quits. I can then turn the key on, lift the solenoid, and start the truck.
thanks alot
Old Jan 30, 2006 | 05:53 PM
TObert's Avatar
thanks alot
Kinda sounds like the pull coil is goin bad. There are timers available that fit the solenoid to prevent it from burning up, shuld the pull current get stuck on. I know the one on my service truck should fit and is only like $80, significantly less than the solenoid...
FIFTHWHEELHAULER
Dec 5, 2009 01:03 PM
FIFTHWHEELHAULER
Dec 3, 2009 10:50 AM
Loosewire
Apr 5, 2008 11:24 PM
finallydiesel
Aug 20, 2004 09:07 PM
