Truck won't shut down
Old Apr 4, 2008 | 04:37 PM
Loosewire's Avatar
Hi all. I know there is a sticky on this somewhere, but I can't seem to find it. My truck won't shut down when I turn the key off. Not sure if it's the solenoid or something in the whole assembly. Is there an exploded view of the whole shut down mechanism? If there is can someone send me the link. Thanx and have a great weekend!
Old Apr 4, 2008 | 04:47 PM
Free89W350's Avatar
I found a couple of pics in a post here is the link
https://www.dieseltruckresource.com/...=Shut+solenoid
Check that out and hopefully it will help expain what needs to be done, it also shows a pic of the "shut down lever".
Hope this helps some
Old Apr 5, 2008 | 09:15 AM
BearKiller's Avatar
Here is a good picture of a kill-cable install :
https://www.dieseltruckresource.com/...0&ppuser=35490
Old Apr 5, 2008 | 03:17 PM
Bigdogbandal's Avatar
Pull the wire off your shut down solenoid on your ve pump. If the truck stays running the problem is with the solenoid. The solenoid has a plunger and a spring and when power is cut it releases the plunger and the spring pushes the plunger down to shut it off. It is more likely to be an electrical problem like your ignition isnt cutting off the power to that wire.
Old Apr 5, 2008 | 06:16 PM
Loosewire's Avatar
I checked the electrical going to the shut down solenoid. It is working properly. So, it must be the solenoid. Can I buy this aftermarket, or is it a Cummins only part? I am going to install a shut down cable also. I am going to install a shut down cable also. Thanx for all the info and help!!!
Old Apr 5, 2008 | 06:18 PM
dodgec68's Avatar
if it is your fuel shut off solenoid, I have had the same problem, and bought a new on for $10 from this place www.dieselvw.com, the first one failed but they sent me a replacement for free
good luck
Old Apr 5, 2008 | 06:26 PM
Loosewire's Avatar
Great, thanx. I will be calling them first thing monday.
Old Apr 5, 2008 | 06:44 PM
frostie's Avatar
This is kind of funny. It seems these issues go in cycles. every few years the same questions come around. If you turn your pump up really far. what happens is you end up blowing a chunk out of the rubber tip on the tip of the shutdown solenoid plunger. You can replace the solenoid but it will probably happen again. Some have modified the plunger by grinding it flat instead of concave. Or you can do the pull cable mod. Neither of my trucks have functioning solenoids. I pull the plunger and leave it out, the plunger can actually cause power problems. Good luck
Old Apr 5, 2008 | 06:54 PM
BigIron70's Avatar
Cummins Guru
There is a lever on the side of pump push it down and it will kill engine.
Old Apr 5, 2008 | 06:58 PM
BearKiller's Avatar
good luck
What are the chances of their $6 throttle-shaft bushing fitting our application ??
http://www.dieselvw.com/InjectorPumpsAndParts.htm
It is about midway down on right side of page.
If it works, that is twenty-bucks cheaper than any other source I have checked.
Old Apr 5, 2008 | 11:24 PM
dodgec68's Avatar
checked.
not to sure but for 6 bucks I think it would be woth finding out, haven't had a problem yet with it except reploacing the gasket when i replaced the governor spring for the 3k , makes a big difference
FIFTHWHEELHAULER
Dec 5, 2009 01:03 PM
FIFTHWHEELHAULER
Dec 3, 2009 10:50 AM
kdohara
Jan 30, 2006 05:53 PM
finallydiesel
Aug 20, 2004 09:07 PM
