Engine Dies When Put In Gear - Automatic
Old Dec 1, 2006 | 10:25 AM
mwolfe's Avatar
I Have A 1996 Dodge Diesel And When It Is Put Into Gear It Dies Unless You Keep Your Foot On The Acclerator Thank You For Any Help
Old Dec 1, 2006 | 10:27 AM
bigdattydiesel's Avatar
i had a gasser do this to me once it was a little spring like piece in the transmission thats right had to talk the whole undertrans apart and replace it dont remember what it was called tho
Old Dec 1, 2006 | 10:35 AM
darkvader's Avatar
whats your idle rpm in neutral
Clark
Old Dec 1, 2006 | 12:40 PM
Joe Mc's Avatar
Had a gaser do the same thing to me before. I had to put it in gear and give fuel quick or it would stall - not very easy on the drivetrain doing so. Also, it would stall out at a stop unless in neutral. It was the torque converter.
Old Dec 1, 2006 | 03:26 PM
JKM's Avatar
JKM
It sounds like the perfect candidate for low idle , Read YOUR ( they are different) engine data plate for correct idle rpm ( in gear with a/c on for autos)
Data plate is found here:
http://www.dodgeram.org/tech/dsl/Fac.../DataPlate.gif
And the idle adjustment instructions are here:
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
Old Dec 1, 2006 | 06:08 PM
Sidewinder's Avatar
I have to agree - low idle syndrome. What is your idle in gear?
Old Dec 2, 2006 | 01:22 PM
dodgetech77's Avatar
+1 more on the low idle adjustment
Old Dec 2, 2006 | 05:13 PM
Mainemike100's Avatar
Agree
I agree, crank up the idle.
Old Dec 2, 2006 | 05:29 PM
new2ctd's Avatar
Don't discount the torque convertor though. There are a few on here that have talked about this in the past.
Torque convertor loads up and stalls the engine.
daddy mopar
Sep 2, 2009 07:57 AM
mr bill
Sep 1, 2009 05:02 PM
stackboy
Feb 22, 2008 11:25 PM
BCarmicle
Sep 8, 2005 08:19 PM
bigjons
Mar 31, 2003 03:27 PM
