Truck dies when put in gear?
Old Sep 8, 2005 | 07:41 PM
BCarmicle's Avatar
My 01' Dodge automatic dies when put in reverse or drive. It has a built TC and VB, TST Comp Box and 80hp Injectors.
I thought it was the torque converter going bad so I had it replaced but that didn't solve the problem. I am also getting a timing advancement malfunction code that won't clear, P1693 is the code. Not for sure if this has anything to do with it or not.
The truck will only do it after it has got hot and been drove for a while, but does it inconsistently. Otherwise it runs fine.
Has anyone else had this problem or have any ideas on what it could be?
Thanks
Brandon
Old Sep 8, 2005 | 07:59 PM
graphitecumnz's Avatar
P1693 is a companion code... it means there is another code stored in the computer and you'll probably need a code reader to retrieve it.
Old Sep 8, 2005 | 08:19 PM
J BODY's Avatar
Sounds to me like your convertor clutch may be applying for some reason. Possible electrical or mechanical, prob perhaps valve body associated.
daddy mopar
Sep 2, 2009 07:57 AM
mr bill
Sep 1, 2009 05:02 PM
stackboy
Feb 22, 2008 11:25 PM
mwolfe
Dec 2, 2006 05:29 PM
bigjons
Mar 31, 2003 03:27 PM
