electrical smoke from defroster??
Old Feb 14, 2007 | 11:37 AM
Dusty Ratcliff's Avatar
this morning I went out & started the truck & hit the wipers & they were frozen to the windshield, so I turned the heat all the way up & turned the defrost on & then the fan to the max, & in a couple of seconds the vents started belching out smoke, I killed the fan & then the motor, got out & checked the belt & it was fine, & looked for any electrical connections that may still be frying, but found nothing, I pulled the dash bezel to see if it could by chance be connections on the CD player, it's aftermarket & I didn't install it, everything looked fine there as well, I started the truck back & it was fine, other than the stinch of the smoke, when I got the wipers thawed out they worked fine on high & low, but any of the settings for the delay just cause them to go up & then stick?????? could it have been something in the wiper motor???? thanks in advance for any help, gonna post this in the 2nd gen. forums as well, thanks alot, Dusty
Dusty Ratcliff
Feb 15, 2007 10:56 PM
Mark Hodowanec
Aug 14, 2004 11:27 AM
jarmar
39
Jan 13, 2004 11:52 AM
AMERICANPIE
Dec 22, 2003 04:20 AM
Nuttymopar
Nov 12, 2003 12:56 PM
