Electrical and Fuel Problems
Old Dec 27, 2006 | 04:56 PM
jbaye73's Avatar
Question Electrical and Fuel Problems
Just swapped out a problem child 53 block, with a take out complete motor from salvage yard with 133k on it. Now my lift pump wont work. It is orig to my truck and was working prior to pulling motor. I then tried to test voltage at incoming line and sits at 8volt. Not enough to run pump. I bypassed the wiring harness to direct 12volt feed with inline switch. got pump to work however bleeding of injection pump is not working one or 2 injectors will spit alittle but not enough to substantiate fuel flow. Oh by the way cracked banjo bolt at IP and fuel flows free. Is there a grounding isue? is there ground lines built into the fram bolts that hold the harnes to the block? Please help if can...
Old Jan 7, 2007 | 02:59 PM
neveragain's Avatar
electrical problems
I take it that the battery voltage is noniminal 12 v's. Pin 7 in harness is 12 volt and pin 6 is grd to vp. I could be that the positive and neg that feed the ECM have a bad connection.I think that that is were the L/P is fed from. If it is bad try using a relay. Run the l/p pos to the coil of the relay and then take the other side to grd. Feed the relay with a fused wire and then to the pump. What else did I forget that I read? Lunch was good. When you loosened the banjo bolt was that on the out going side? The fuel going into the pump was good.
Old Jan 10, 2007 | 10:53 PM
jbaye73's Avatar
Problem was with the cam sensor sending false signals to the computer on side of block... Thanks for the help...
Old Jan 11, 2007 | 08:25 AM
XLR8R's Avatar
What did ya do with your 53 block?
Old Jan 11, 2007 | 08:43 PM
jbaye73's Avatar
The block is sitting in the salvage yard. Why do you think I should have kept the core? It was a $1000 core charge. Cummins and Dodge said they would do nothing to fix my problem...
Old Jan 12, 2007 | 08:12 AM
XLR8R's Avatar
Did it crack from core shift?
DJ Turbo.
Oct 13, 2011 09:11 PM
newtododge
0
Mar 9, 2007 04:07 PM
FastSS
Sep 8, 2003 01:47 AM
FastSS
Jan 8, 2003 05:53 PM
TurboAZ
Oct 11, 2002 12:34 AM
