Need serious Help with my 24v
Old Jan 4, 2007 | 06:11 PM
SuckFumes1984's Avatar
I was driving up the road yesterday and my truck just lost power. It still runs but it runs rough almost like it isnt hitting on all cylinders. I still have decent fuel pressure to the vp and I dont have any codes. I have unhooked my tst and used the superchips tuner to go back to stock programing. I pulled the valve cover to make sure that I didnt bend a pushrod or something but everything is ok there. There is no signs of a blown head gaskes either. Im not sure what to check next. Do you think my vp just took a crap? It has 141,000 miles on it. Any help would be greatly appreciated. Also how do I do a compression check on a 24v?
Old Jan 4, 2007 | 09:29 PM
Timmay2's Avatar
Do you have access to an OBD-II reader? Very handy to get if you dont have one.. to hook up just to see if there are any obvious problems the computer knows about.
Some have had a random loss of power before losing the VP completely.
Running rough can also be attributed to a lack of boost pressure. The fuel systems on these trucks could be a little smarter (based on boost pressure instead of throttle position... what the heck were they thinking?) so if theres a leak anywhere in the intake tract the truck can run rough because its dumping fuel expecting boost to follow.
Any smoke or smells?
XLR8R's Avatar
Is it smoking?
Old Jan 4, 2007 | 09:38 PM
I have checked for codes and it is not showing any. I did a check of the intake and found no leaks. I ran it and it builds boost. It really isnt smoking eather.
Old Jan 4, 2007 | 11:36 PM
PaulDaisy's Avatar
Stupid question: is there enough fuel? Maybe it sucked in some air?
-P
Old Jan 5, 2007 | 04:49 AM
Rauschbo's Avatar
The VP going south is ALWAYS a possibility - and I'm not sure that it will throw a code in every instance! Anybody know of a way to test a VP that may be dead but hasn't thrown a code?
Another thought - perhaps you've had an injector go south, or the IC has a leak, are you still making boost?
Old Jan 5, 2007 | 08:05 AM
farmer dave's Avatar
Have you hooked up a fuel pressure gauge to see what you are getting? If you think that it might be fuel related I would start there.
Old Jan 5, 2007 | 08:14 AM
smokindog's Avatar
Sure,
Same as bleeding the lines after replacing a VP.... crack # 1 and #3 injector lines and see if you are getting a solid spray of fuel or just a dribble. Best to place a piece of cardboard behind the open lines to get a good picture of the spray.
Old Jan 5, 2007 | 09:37 AM
Thanks guys. I will try cracking the injector lines today. I know the lp is working because I still have 12 psi to the vp.
Old Jan 5, 2007 | 10:34 AM
XLR8R's Avatar
Make sure you eliminate bad fuel/water in fuel as a cause before you R&R the IP w/o a code.
Old Jan 7, 2007 | 03:37 PM
I have cracked the lines at the head and they seem to be flowing fuel but its not spraying out that hard. How hard should it come out?
Old Jan 9, 2007 | 12:05 PM
PaulDaisy's Avatar
I suppose pretty hard at some 30,000 psi, provided you cracked them enough (not to come off completely!)
-P
Old Jan 9, 2007 | 12:24 PM
b4wheeler's Avatar
30,000 psi???? ARe you nuts.. That may be for the common rail third gens, but I thought the 2nd gen 24Vs ran the same pressure you see at the pressure gauge.
You should see pressure, like putting your thumb over the end of a hose....
Where in Maryland are you???
We have great suport in the Baltimore area.
Old Jan 9, 2007 | 01:33 PM
Sea:\>Drive's Avatar
MD Chapter is great and a lot of help. Get in touch with us.
BTW - the pop-off pressure of the injectors is ~4500psi so I would think the pressure at the connector tube would be much higher than fuel pressure to the injector pump. Not as high as a common rail, but a bit more than a hose.
Old Jan 9, 2007 | 03:21 PM
XLR8R's Avatar
Stock rail pressure shouldn't exceed 27K psi
