Need serious Help with my 24v
Old Jan 9, 2007 | 03:48 PM
2broke2smoke's Avatar
Originally Posted by XLR8R
Stock rail pressure shouldn't exceed 27K psi
his sig says '01 24 valve ... quick talking about his rail
Old Jan 9, 2007 | 03:59 PM
XLR8R's Avatar
Originally Posted by b4wheeler
30,000 psi???? ARe you nuts.. That may be for the common rail third gens,
2broke - I was responding to this
Old Jan 11, 2007 | 12:10 AM
biododge1's Avatar
the ip can reach 17,500psi---per dodge tech manual
Old Jan 11, 2007 | 08:43 AM
D2 Cat's Avatar
b4wheeler 30,000 psi???? ARe you nuts.. That may be for the common rail third gens, but I thought the 2nd gen 24Vs ran the same pressure you see at the pressure gauge.
You should see pressure, like putting your thumb over the end of a hose....
Just so someone doesn't get hurt, the pressure guage measures the lift pump pressure to the injection pump. The pressure at the injectors is much greater because the IP puts out (up to) 17,405 PSI. That's why they're called HIGH PRESSURE lines.
If you think you have a leak on one of the high pressure lines you should check for it with a piece of cardboard as a target area, not your finger or hand!!!
Be safe.
Old Jan 12, 2007 | 11:19 AM
SuckFumes1984's Avatar
Thanks for all of the help. I ordered a new IP. After checking everything else its the only thing I figure it can be.
roscos185
Oct 23, 2008 10:00 AM
Jeremy Cusick
Jan 29, 2007 12:44 PM
Rambunctious1
15
May 22, 2006 03:19 AM
Herrin811
Jan 2, 2006 12:23 PM
dsljunkie
20
Sep 13, 2003 01:54 AM
