edge comp
Old Aug 21, 2005 | 01:05 PM
Adam F's Avatar
edge comp
Ok I have a 99 3500,with a new lp and ip,everything is stock except the edge comp,everything is fine on the low setttings,but on 5.5 it sputters out,it doesen't die but just runs like crap,so ... any ideas on what it could be?
Old Aug 21, 2005 | 02:43 PM
Tiny's Avatar
Sounds like you are running out of fuel. What does your fp gauge do at WOT on 5x5? Is it ok on the lower settings?
Old Aug 24, 2005 | 07:23 AM
mooseman's Avatar
Check fp as stated above. Also check your pump wire connection. Mine would run fine on lower settings but had the same symptom on 5x5. Ended up being a bad connection on the pump wire.
Mooseman
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
