Duramax issues
Old Jul 11, 2008 | 08:23 PM
JKM's Avatar
JKM
Duramax issues
Just had a call from a friend , his 01 D-Max is having some issues , it has just under 200 000 kms on the clock , the last couple days it has been running rough at idle , and started losing power, it's also blowing oil out of the breather tube on the right front corner of the engine , enough to coat the underside of the truck he says...
Any thoughts or suggestions?
Thanks, Jayme.
Old Jul 11, 2008 | 08:26 PM
Engine oil smell like fuel?
Old Jul 11, 2008 | 08:52 PM
duratothemax's Avatar
injectors. tell him not to run it anymore unless its to take it to teh dealer to have the injectore replaced
Old Jul 12, 2008 | 07:25 AM
JKM's Avatar
JKM
what is the injector warranty on those trucks?
Old Jul 12, 2008 | 09:09 AM
roughstock's Avatar
Injector warranty should be to 200,000 miles. That is what the letter that the dealership sent me.
He needs to check the oil and if it is over full and smells like diesel. he has bad injectors. It should set off CEL. It should go in to "safe mode"
Old Jul 12, 2008 | 11:22 AM
dozer12216's Avatar
He should immediatelly after repair trade for a RAM!!!!!!!
Old Jul 12, 2008 | 04:58 PM
In most cases, no. Ive only seen a very small number of trucks actually set codes due to bad injectors. Almost all of them just run like crap, smoke, and fill the crank case with diesel. Keep driving it, and it wipes out a bearing.
Alan_Reagan
Jul 26, 2009 01:13 PM
Ray,IN
Mar 12, 2003 10:29 PM
NWDave
Dec 14, 2002 07:42 AM
Extreme Diesel
16
Nov 29, 2002 06:14 AM
Nov 23, 2002 03:47 PM
