dumb ? of the year
Old Apr 19, 2006 | 06:17 PM
Cummins Freak's Avatar
dumb ? of the year
OK dumb question of hte year but how do i tell if my trans is slipping? i only ask because i thought it was holding fine but have come to find out that shawn(doodha) said it sounded like it was slipping when i was leaving his place.
SO Again how do i tell i really need to know so i dont dysrtoy my trans till i can afford a new one from dave.
Old Apr 19, 2006 | 06:41 PM
volly818's Avatar
If your truck has a tach watch it when you are speeding up. If your trans is slipping right when it goes to shift you will see the tach jump up then back down. If the tach does not jump up and just goes up with a normal increase the drops right off when the trans shifts your ok.
Old Apr 19, 2006 | 11:42 PM
Ian's Avatar
Ian
and when it gets really bad it will be almost like revving in neutral, and then it will catch.
Old Apr 20, 2006 | 10:28 AM
WSA308's Avatar
You should be able to feel it in the seat of your pants if you pay close attention, a slight power variation (catches.....slips.....catches) Also you will notice a significant increase in Noise and vibration with no increase in speed as we are used to with the Cummins. Another real easy way id to pull your Tranny dipstick and smell it. If smell burned and has brown tinge, she's too late and you will soon be walking.
Another small piece of advised would be to have the transmission filter changed - not sure if/whent the last time was that you had it done but since I have already taken out one tranny, I will be servicing the trans twice per year. And I will not go to one of those 5 minute Lube shops either. Take it to a transmission shop for all maintanance as they will be able to detect a potential issue long before it happens.
Old Apr 20, 2006 | 04:07 PM
thanks guys i'll have to watch for those symptoms
Rickcher
May 4, 2014 10:37 PM
horsinaround
Apr 14, 2012 06:35 PM
trophystock
Jul 16, 2006 11:00 AM
