DTC P 2146-Bank 1
DTC P 2146-Bank 1
First day with my new edge Juice with Attitude...Didn't do anything to crazy and my check engine light came on just pulling out of a parking lot...I checked for the code and it gave me...P2146 - Bank 1 Cylinders (1-3) Shorted High or Low...Any one know what that code is or were I could look it up at....Thanks for any help...
This is a Chrysler unique code, and is part of the range assigned to the fuel injection system. In this case it is telling you that something is pulling the first bank of injectors power supply low.
What I would do is disconnect the battery grounds, let the truck set for a few minutes, and then remove the Edge. Reconnect the batteries and let the truck roll through the entire starting light sequence and then start it. The codes will likely go away.
texguy2124
12-07-2006 08:34 PM
MoparKen
09-04-2006 04:56 PM
Sittenbull2
16
10-17-2003 06:37 PM
