wire tapping problems(-20C)
Old Nov 24, 2006 | 05:09 PM
S.Dodge's Avatar
I'm checking my comp wire to make sure i have the right one tapped, there are 2 sets of 2 wires, one wrapped ina a mesh and one wrapped ina plastic, the set wrapped in mesh has 2 wires and the one i have tapped is the hightest one is this correct or do ia have to use the other set, i picked a bad time to do this its -20C right now.
Old Nov 24, 2006 | 09:12 PM
scottsjeeprolet's Avatar
Check out page 14 of this manual. it is a PDF for the Edge web site. it clearly shows the correct wire to tap.
Good luck
http://www.edgeproducts.com/product_...manual-142.pdf
Old Nov 27, 2006 | 12:26 PM
REF>Lancer's Avatar
I know you didn't ask,but I'd skip that wiretapping thing...its bad for the IP.
My rebuilt IP made it 30k
At 21lb at inlet all the time.
Old Nov 27, 2006 | 08:49 PM
blackdiesel's Avatar
Registered
Its the luck of the draw. Sure, the tap dosnt help the vp. However you cant blame the dead injection pump on the tap. Cause you never know what could have happened if you didnt tap it
ive seen some un - tapped vps last only a few thousand miles. and ive seen some tapped vps run 100k or more.
Old Nov 27, 2006 | 11:07 PM
XLR8R's Avatar
Sucks to have to play the lottery like that.
Old Dec 8, 2006 | 10:28 AM
REF>Lancer's Avatar
Not tapping the wire is NEVER bad for the pump though,while sometimes tapping is...that was just my .02
mamajo
Jan 25, 2005 03:00 PM
01350banshee
Jan 17, 2005 10:55 PM
More Power
Jan 23, 2004 06:52 PM
gsdog1
Dec 29, 2003 06:23 PM
TPilaske
16
Nov 22, 2002 08:15 PM
