Drain plug cracked?!?!?!
Old Nov 22, 2002 | 01:25 PM
Dodgezilla's Avatar
I just changed my oil last week and now my drain plug is leaking. I bought a new $7.00 plug but I was wondering if this is a common problem.. It is actually leaking from the center of the drain plug. Not from around it. The dealer told me they always put a new drain plug in these trucks when they change the oil. This sounds strange to me. Oh well, I hope the new one works. Now I have to drain all the oil just so I can put the plug in....
Old Nov 22, 2002 | 01:37 PM
drafalske's Avatar
Re:Drain pug cracked?!?!?!
I've changed my oil several times and never replaced the plug. Hmmm... never heard of such a thing, drain plug breaking that is. Good luck.
Old Nov 22, 2002 | 01:44 PM
TPilaske's Avatar
Yeah, I think that's a common problem. Pickup a superplug or another aftermarket plug from Geno's. Solves that issue. ;D<br><br>Tony
Old Nov 23, 2002 | 12:59 AM
Bart Timothy's Avatar
The finger touch drain plug from Genos is far and away the slickest way for chganging oil. It must be modified to drain the pan completely, and is a little slow at draining, but you'll never have to take off the drain plug again.
Old Nov 23, 2002 | 02:40 AM
dalton4's Avatar
I've read several posts on the plan plug fracturing/breaking. I have a new plug and copper sealing washer on hand in case it happens to me.<br><br>Jerry
Old Nov 23, 2002 | 06:39 AM
Dodgezilla's Avatar
Thanks guys. The new plug looks to be a little better than the stock one. I'll find out later on when I put it in....
Old Nov 24, 2002 | 07:31 AM
Dodgezilla's Avatar
Re:Drain plug cracked?!?!?!
I got the new plug in and all is fine. You would think that the plug would come with the washer. NOPE!! I put some RTV on both sides of the washer and torqued it to 40 lbs . The old plug was cracked around the entire circumference of the base. Be careful when you tighten these.....<br>And as far as the new piece being better, as I stated in my last post, it is not. It's exactly the same!!
klx650a2
Apr 20, 2009 05:25 PM
klx650a2
Jan 10, 2008 12:08 AM
Crimedog
Oct 23, 2007 08:37 PM
wooff
May 1, 2003 11:22 AM
WVPANHANDLER
Feb 1, 2003 08:23 PM
