Does anyone know how to remove fuel lines???!!
Old Sep 10, 2004 | 07:26 PM
Captain's Avatar
Does anyone know how to take the freakin fuel lines off from the sending unit? I've tried everything and went to 3 auto parts stores. all they sell is ford and gm fuel line removal tools. I'm about to cut the hose off at the steel tubeing on the frame and just reaplce it all with flexable rubber type line insted of this freakin plastic quick connect junk.
Old Sep 10, 2004 | 09:17 PM
nitrousn's Avatar
as far as i know blow them out good and spray them with some wd-40 and pinch the tabs togeather to release the lock. keep them depressed and twist and pull the line. it should release.
Old Sep 10, 2004 | 10:27 PM
infidel's Avatar
The fuel lines are removed by pressing on the tabs of the connector while gently pulling on the fuel line, no twisting required. To replace just push them on.
Old Sep 11, 2004 | 01:45 AM
Captain's Avatar
hmm I thought I did that but ill try again. and give the wd40 a shot too. thanks guys. we'll see what happens.
Chris
Old Sep 11, 2004 | 07:33 AM
Geico266's Avatar
I cut mine off and used hose clamps. They are pretty weak.
Old Sep 11, 2004 | 12:10 PM
DZLPWR's Avatar
Mine had siezed to the metal line and i had to cut them off with a cutting wheel.
RoadDiesel
Aug 7, 2012 06:06 PM
morkable
ABDTR #5
16
Sep 10, 2009 11:41 PM
drewallen42
Apr 14, 2007 01:07 PM
Dodgezilla
Jul 17, 2004 05:24 AM
moparman2
13
Oct 13, 2003 08:04 PM
