Do I need a new ECM for voltage regulator problems?
Old Jan 24, 2008 | 10:11 AM
shecom3's Avatar
Voltage gauge started dropping off to zero and check gauges light started coming on.It would temporarily reset itself back to charge once I turned off and restarted the truck.Took it to a shop to get alt/batt tested and was told the voltage regulator was acting up which is located in the ECM.Just want to know if this sounds like correct info...if so I will start shopping for new ECM.
Old Jan 24, 2008 | 10:13 AM
shecom3's Avatar
Forgot to mention....truck is 01 auto
Old Jan 24, 2008 | 10:15 AM
volly818's Avatar
Do a search you can put an external regulator on it.
Old Jan 24, 2008 | 11:50 AM
infidel's Avatar
Installing an external regulator is easy, cheap and won't effect anything else.
Many people claim that they actually do a better job regulating than the PCM.
Just disconnect the stock wires from the alt, tape them up and wire as below.
Any 12 volt regulator will work. Wires to the alt are interchangeable.
Old Jan 24, 2008 | 03:33 PM
Katmandu's Avatar
Arrow
Get your Codes read and report back.
Old Jan 25, 2008 | 11:02 PM
dozer12216's Avatar
My experience is internal voltage regulator is reliable.
Perhaps take alt off and have tested by friendly parts store. This eliminates the alternator as a variable.
The two wire connector test after reinstall of alt.
One of two wires in small connector at alt is green(?) and feed from relay.
With engine running you should read bat voltage on wire.
The other wire is blue (?) and is ground control for rotor. It will read less than battery voltage of perhaps 8-10 volts or less. If reads batt volts you may have a damaged wire to PCM. It could also be a bad pcm. Spread terminals are frequent cause.
Old Jan 26, 2008 | 12:20 AM
Katmandu's Avatar
Exclamation
Unless the PCM's internal voltage regulator gets shorted out and damaged by a shorted/BAD CPS (crank positioning sensor).
Old Jan 26, 2008 | 10:03 PM
sawmill's Avatar
Will this work with my 97? wanting to overcharge not good
Old Jan 27, 2008 | 07:27 AM
RAM2940's Avatar
If you put a external regulator on, will this fix the check gages light and gage on the dash, or do you ride around listening to the warning bell and dash light on all the time.
Old Jan 27, 2008 | 10:32 AM
Katmandu's Avatar
Arrow
I have a PCM out of a 98 that "may" work For Sale for $150.
Check your #s on your PCM and PM me if you're interested.
The # on mine is..... 56040139AC
Check out the chart below...
http://www.aa1car.com/library/2004/c...ailability.pdf
Old Jan 27, 2008 | 12:05 PM
sawmill's Avatar
Rebuilt the alt last week new brushes and rectifier the gauge steadily rises under high throttle until the light pops on back off the gas it drops light goes out.Last resort is the regulator
Old Jan 27, 2008 | 01:02 PM
infidel's Avatar
I've only done this mod to 12 valves but assume it would be same on all years.
No lights or bells, think these are a function of the dash cluster rather than the PCM.
Old Jan 27, 2008 | 03:09 PM
Dave Miller's Avatar
I've got the PCM from my 97 5spd 4x4 3500 that I got from dealer cause I couldn't find one on ebay. Cost $600 sell $350. Used for 5 min test and wasn't my PCM. Replaced the CPS and reused my old PCM. Got install instructions and original MOPAR box it came in.
Maybe the CPS is causing your problem. Cost about $100 for CPS. What other symptoms do you have?
imbodie
21
Jan 8, 2024 08:49 AM
Svenne
Mar 18, 2015 05:05 AM
kiszka6911
Dec 14, 2011 04:58 PM
CTD2001
Sep 30, 2007 07:44 PM
Common
Jan 11, 2007 09:05 PM
