diesel in oil
diesel in oil
started losing oil presure little bit at idle ,changed oil. It was black and thinned, probably diesel. After oil change oil pressure came back strong but was short lived. Oil a mess again. Truck has 198000 miles , no engine work done, first promblem.
How the Diesel is getting into the oil is heavily dependent on what year your truck/engine is.
And, are you sure it is Diesel?
Have you had an oil analysis done?
phox
Oh, and seeing that this is your first post here, Welcome!
You'll find a lot of knowledgable folk hang their hats here.
Myself, I don't wear a hat, but keep the hat wearers in line.
phox
I would also be checking the lift pump if the engine is running smooth and appears to be getting even fuel to all cylinders. The lift pump is a mechanical pump and an inside pump leak could put fuel into the engine.
Re: diesel in oil
When you check the oil is the level high?
96 , 2500, 4x4, 5 speed. engine running a little ruff , starting to lose power on takeoff. oil change only lasts about a week before pressure is gone. Starting to lose her, help. Scared to go to the dealership
Beats me. If you're in doubt, replace the thing. The 1st gen pumps are around $40. It's a diaphragm pump just like an old gasser, prone to the same problems. The 2nd gen is a piston design, puts out a lot more pressure and lives longer - but it costs 3x as much.
raven392003
13
07-02-2007 06:52 PM
GlennRMK
05-24-2007 10:46 PM
