Diesel Leaking
Old Nov 20, 2010 | 02:22 PM
randyb's Avatar
Diesel Leaking
Hey guys,
Truck in my signature. Truck is back to stock except for exhaust and intake and has 90,045 miles on it as of today.
Went to town today approximately 40 miles, no problems. Grabbed a bite to eat and when leaving my wife hears a louder than normal clicking or rattling from the engine compartment and we immediately smell diesel. I pull over and see that i have fuel all over the back side of then engine. The front differential is also covered in diesel, however the front of the engine is not wet. I did not have any codes either. Truck now won't start at all and is sitting on my trailer at a buddies house until he can help me haul it home tomorrow. FYI, a 1/2 ton Chevy is not a good tow vehicle for a 3/4 Dodge.
Looking for thoughts from all my diesel friends. Things to check and look for.
Thanks guys,
-randy
Old Nov 20, 2010 | 02:36 PM
Condor's Avatar
Check injector lines, probably #4 is cracked.
Old Nov 20, 2010 | 03:11 PM
Onemoparnut's Avatar
X2!!!
Old Nov 20, 2010 | 03:14 PM
Blueboy's Avatar
When you tried to start, did someone look for
leak under pressure.
Old Nov 20, 2010 | 03:27 PM
J BODY's Avatar
....and for the rest of you on-lookers checking to see if your fuel line isolators are tight can prevent this issue.
Old Nov 20, 2010 | 04:40 PM
randyb's Avatar
I had my wife turn the key to the run position and I did notice fuel was spraying in a mist. However, I really wasn't in a place to do indepth t-shooting so I did not investigate further.
I will be working on this as soon as I get the truck home.
-randy
Old Nov 20, 2010 | 11:21 PM
J BODY's Avatar
#4 line.
Old Nov 21, 2010 | 08:25 AM
randyb's Avatar
Thanks guys, I will go for the #4 line first.
Can someone give me some background as to why this line is so problemmatic and people are seeing this alot.
Old Nov 21, 2010 | 05:37 PM
STANGGT40's Avatar
i had this same problem friday morning:
https://www.dieseltruckresource.com/...y-t280827.html
it sucks, but at least it's an easy fix!
Old Nov 21, 2010 | 09:15 PM
randyb's Avatar
Problem found. Appears that #4 line is leaking up by the input of the manifold. Will try to find one tomorrow and replace. Once again, THANKS EVERYONE!!!
Old Nov 22, 2010 | 07:27 AM
patdaly's Avatar
Buy 2.........
#4 Line, never leave home without one.........
lilsuzuki4x4
Sep 1, 2011 01:50 AM
oliver foster
Nov 13, 2009 08:58 PM
Brad4406
Oct 30, 2009 11:25 PM
Towrig
15
Jun 16, 2004 11:17 PM
ouchman
Mar 31, 2004 02:10 AM
