Dead Vp44 ?
Old Mar 25, 2006 | 05:23 PM
More Power's Avatar
Dead Vp44 ?
Installed a comp on a 1999 automatic dodge today with 144,030 miles on the clock didnt make it out of the garage and it was blowin white smoke and missin to beat all at around 2000 rpm or anything over an idle. Unhooked everything disconected batteries for about an hour hook batteries back up no better with comp unhooked still miss and smokes and has no power. Is the vp dead or could anything else have died. No way to check codes tried thhe ignition on off trick. Any help appreciated.
Old Mar 25, 2006 | 06:10 PM
scottsjeeprolet's Avatar
Did you poke the wire? If so did you accidently break the wire? I would check this out first before condemning the VP44.
Old Mar 26, 2006 | 12:40 PM
Dr. Evil's Avatar
Obviously, you need to check the fuel pressure and scan for codes.
Old Mar 26, 2006 | 06:41 PM
More Power's Avatar
Scaned for codes and it had none the pump wire is not cut and fuel pressure is low about 8 psi at idle. Is vp Dead?
Old Mar 26, 2006 | 07:06 PM
piperca's Avatar
Looks like your LP is. Might want to change it and see what happens. I wouldn't run out and buy a new VP without checking out everything. If you're sticking with a stock LP, hook yourself up with one of the campaign pumps for $70. Comes in a kit from Cummins. Do a search and you'll find the part number. I got mine for sixty something plus tax.
Old Mar 26, 2006 | 07:14 PM
More Power's Avatar
It is just funny that truck ran fine until we installed comp now it misses and smokes like hell white smoke. Didnt even drive it with comp just started it and it was smokin and missin.
Old Mar 26, 2006 | 07:26 PM
I had a simular problem when installed the comp. i neglected to tighten the ground on the comp. Ran like crap and set a couple of codes.
I found it and fixed it had the codes cleared and all is well. Hope it turns out to be something simple like this for you.
I know when in a panic situation we all neglect to look for the obvious or simple things that might be wrong.
best of luck
scotte
Old Mar 26, 2006 | 07:29 PM
More Power's Avatar
But with everything unhooked and no codes it still runs like crap could something have happened to the apps should i reset it.
Old Mar 28, 2006 | 06:39 PM
More Power's Avatar
Turned out to be a short in the wiring harness of the map sensor. Go figure.
Old Mar 28, 2006 | 06:51 PM
P.J's Avatar
P.J
Lucky you.
Old Mar 28, 2006 | 08:11 PM
Dr. Evil's Avatar
Still....You might know this or maybe not....BUT, it is NOT uncommon to kill the VP-44 after tapping the wire....have you poked the pump wire??
Old Mar 28, 2006 | 10:33 PM
piperca's Avatar
You still need to change that LP ... 8psi at idle is too low!
Old Mar 28, 2006 | 10:37 PM
Dr. Evil's Avatar
No doubt....
Apocalypse
Jul 1, 2008 12:09 PM
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
