Cross member removal
I'm working at pullinmg my Tranny and T-case out but having a heck of a time getting the Cross member down....
Removed the skid plate and all the croos member bolts as well as the transmission mount nuts, but that cross memebr is in there tight.......
What is the trick to getting it out??
Spread the Frame
Some folks use a porta-power. If you have or can rent one it's a good choice. I just used a small 1 1/2 ton bottle jack and a piece of 2X4 cut to the right length to fit between the frame rails. Just go back 8 or 10 inches from the cross member and spread the frame. The cross member should then move UP and Back and down and out. Don't try to spread it enough to take the cross member straight down (the ends and the mounting surfaces are tapered). Good Luck!
You don't need too heavy of tools. The frame rails are taperd or saddles to hold in the crossmember. The crossmember is therefore wider at the top than the bottom. You actually need to hammer up to get the member loose, then slide it either back or forward to clear the area where it bolts to the frame to spin it out.
Make sure when you put the bottle jack on it's side the "pump" cylinder where you put the jack handle is on the lower side. Most jacks will work on their side if the pump cylinder can get oil.
Just make sure when you put the bottle jack on it's side the "pump" cylinder is on the lower side. Most jacks will work on their side if the can get oil.
That all depends on if his helper (Me) really took all the bolts out on his side and didn't leave one in by mistake. (And we ain't even gonna talk about the "tranny jack incident",,,,,WHOOPS! Tim will tell ya)
Used a BFH to get the crossmember out of my 4WD '98 Ram, but this spring I removed the one from my '05 w/o anything but the ratchet-drive and sockets.
You can slide it to one side, up all the way then drop the other side free of the the bracket and pull it out.
Big Joe
Jul 1, 2005 04:34 PM
zookeeper
Mar 17, 2005 05:27 PM
