code help
Old Jul 12, 2010 | 05:18 PM
dakotajam's Avatar
code help
Hey guys,
I'm in Gettysburg PA tuck is throwing two codes. P 2149 & P 204.
Old Jul 12, 2010 | 06:33 PM
jpdodge150's Avatar
P2149= Fuel injector group B supply voltage circuit open
P0204= FUEL INJECTOR 4 CIRCUIT/OPEN
Check your injector harness that everything is tight and secure and ohm out injector #4. It should be no more than 1ohm DISCONNECTED! Do not ohm it while it is connected to the harness. I've heard that the common fault is something to do with the valve cover gasket that the wiring runs inside of? So check to be sure the harness is still good. Replace the injector if it test bad and you should be good to go. I'm a 12v guy so feel free to slap me if I'm wrong anywhere.
Old Jul 12, 2010 | 06:53 PM
dakotajam's Avatar
Thanks, was afraid that it was injector issue. no smoke at all that's what threw me.
Any good diesel shops in Gettysburg. No tools for that kind of work. and way to far to limp home with the camper
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
